Removing the speedometer needle
My needle moves but nothing else, how do I separate the needle from the shaft?
![]() Join Date: Jan 2011
Re: Removing the speedometer needle
What are you trying to fix? I try and not pull the needles as they are hard to get back on in the correct location.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
The gears are stuck and not moving, trying to get it back working so I can have a speedometer back. I can some what gauge my speed without it
I would replace the head. I have not had much luck reviving dead ones with out replacing parts. I lube them first and give them a spin with the drill to test. If good I'll redo them. After fixing one up and resetting the mileage I spin them up again and put a mile on it.
Jimmy
