Re: Johns 66
Originally Posted by Johns 66
Thanks John...I appreciate the knowledge and advice.
Radiator shopped called and said that the heater core was just fine...so they are going to back flush it and it should be good.
The radiator is a different kind of story...When I got the truck I knew it leaked...so before I left I put some grits in the radiator to stop the leak so I could get it home...Well it hasn't leaked since but I could tell that some of the fins were broke....They tested the radiator and it didn't leak...guess the grits are still holding up.
Anyways I decided to have new cores put in it...I figured since the motor was being rebuilt that no need to run an old radiator...So they are going to put a 3 core high efficiency set of cores in it.
Had to do chores yesterday so didn't get to work on the ole truck last night.
I did find an automatic steering column that I am going to be buying today...around 250.00...The company I bought it from has original columns and if I am correct they go through them and make sure everything is right....It also is adapted to work perfectly with the 700R4....so I will see when it gets here.
Can I ask who you are getting the steering column from?
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
