Old 05-28-2017, 11:15 PM   #1
loujizzel
Average cost of triangulated 4 Link
What's up guys I live in Temecula California and I wanted to bag my 73 C10 I was told I should get a triangulated 4 Link and after tons of research I think a triangulated 4 Link is where I want to go unfortunately when I started looking for the cost to install the triangulated 4 Link the prices they gave me blew me away does anybody know of a shop that's decent in the cost of install I've had quotes anywhere from 2500 - 3000 just for the install of the 4 link thats not including the air ride install.... i am ballin on a budget for real....can someone give me a shop or a person to call or go to I'm willing to travel a hundred miles outside of my ZIP code in Temecula down to San Diego even Los Angeles thanks in advance for any replies
loujizzel is offline   Reply With Quote
Old 05-29-2017, 01:13 AM   #2
andrewmp6
Re: Average cost of triangulated 4 Link
Yeah 3k is cheap since its a lot of labor hours.Why not use a bolt in 4 link kit so you can do it yourself and spend less?
Old 05-29-2017, 02:18 AM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
http://www.brotherstrucks.com/73-87-...nfo/4BK87SL-B/
Malo83 is offline   Reply With Quote
Old 05-29-2017, 05:37 AM   #4
andrewmp6
Theres bolt in systems like http://www.bcfab.com/73-87-Chevy-C10...em_p_1818.html http://www.ridetech.com/store/ridete...73-87-c10.html and http://www.cachassisworks.com/c-1139...r-air-bag.aspx also keep in mind some 4 links won't work with the factory side saddle gas tanks so do your homework before buying one if that matters to you.
Old 05-29-2017, 01:47 PM   #5
tinydb84
tinydb84's Avatar
I have not seen that BC Fab kit before. Looks nice.
Like Andrew said it will be hard to find someone to install it cheap. Have you checked with the local car clubs in the area? I know a few guys in my local clubs who work out of their garage and do some quality work for half the price of the local shops.
Remember you are often paying by the hour. You can definitely do some work to make the install cheaper. Are you willing to do the wrenching yourself? If you pull the bed, clean everything, buy the kit, and spend a good amount of time looking around I am sure you will find someone who could do it cheaper. I'd rather do the work myself then pay someone else 100 bucks an hour to take my bed off and degrease the frame.
David
Instagram: myfabguy
Old 05-29-2017, 05:42 PM   #6
Half Assed
Half Assed's Avatar
Then do all the work yourself.
There are calculators online to help you do the math on your 4-link so you don't have issues.
Half Assed is offline   Reply With Quote
Old 05-29-2017, 07:21 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Im curious who told you you need a "triangulated" 4 link? My personal experience is a "triangulated" 4 link is not a good system if your truck is SWB. The problem is there isnt adequate for the upper bars to triangulate properly. Consequently the rear has a tendency to walk back and forth.
If you really want a 4 link, there is a simple answer and its reasonably priced. RideTech offers a bolt on 4 link that easy to install. I have been running one under my 77 Cheyenne for many years and have had no issues with it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-31-2017, 06:40 AM   #8
andrewmp6
Only time i can see a triangulated 4 link being great is on a rock crawler/off road.A bagged truck i rather have a parallel 4 link like that ride tech kit and the longer the links the better the ride.The big thing is air ride is not cheap and if you try to cut corners it comes back on you and you end up spending double in the end to do it over right this time.
Old 05-31-2017, 12:37 PM   #9
daddyjeep
daddyjeep's Avatar
The suspension for my Jeep was 100% designed and built by me and I have $3,000 in it. I know a rock crawler is not an apples to apples comparison, but the point is 4 links can get pricey. By the time you buy the tubing, brackets, rod ends, shocks, bags, and air ride components I would think $3k is a bargain.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-31-2017, 03:42 PM   #10
midnight rambler
midnight rambler's Avatar
get ahold of Jayson at camods here in san diego on instgram he has great prices and does great work. Jayson Pang (@camods) • Instagram
midnight rambler is offline   Reply With Quote
Old 06-01-2017, 06:29 AM   #11
cadillac_al
If it's layin low nobody is ever gonna see it. I would cheap out and use some really soft leaf springs. I'm not a lowrider so I don't know why leaf springs can't be used.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-01-2017, 09:11 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Technically you are correct. Well at least about the leaf springs. That "lowrider" term has nothing to do with a bagged truck.
On my 77 Cheyenne we originally used a Air Over Leaf (AoL) system. All but the two top leafs were removed from the spring pack. Air bag were installed outboard of the frame. This system worked just fine till I decided to upgrade to a RideTech 4 link.
Articles-
"Refining Sierra"
Old 06-14-2017, 09:32 AM   #13
JohnJ@RideTech
JohnJ@RideTech's Avatar
X2 The Ridetech 4-Link retails for $2170 and comes with shocks. All you need is some type of air management system. Check out the link below and let me know what you think.
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
