![]() Join Date: Jun 2016
Re: A/C System rebuild - what should I replace?
Because orifice size in the blue tube works best in systems converted from R12 to R134.
Go search the forums over at www.ackits.com and there are discussions about it.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
#2 | |
![]() Join Date: Nov 2011
To that point. I put all original system back except I put R134 in, I was told by the tech that the condenser I had in it (stock) was not conducive to 134, the tubes are bigger and spaced out too far, the recommended condenser for 134 is smaller tubes and closer together. My AC with all new old stock is marginal at best. I am going to evacuate the r134 and go to R12 soon.
Dale - ApacheIvan 1972 Chevy Custom/20 Custom Camper Highlander http://67-72chevytrucks.com/vboard/s...d.php?t=740479 Original Owner ** Do you have a 1972 Plaid Pickup?** |
#4 | |
Any suggestions on where to find the parallel flow style condensers for our trucks? I did a google search but came up short.
#6 | |
#7 | |
He said he would take my money if I insisted but that he felt the need for full disclosure.
#8 | |
I knew after I typed that the question would be asked. I would have to go back through my notes on the project for the manufacturer. I found them through various online threads for people wanting a custom/built to spec condenser.
