Old 07-06-2017, 01:22 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Re: drop blocks
Looks like the frame is sitting on (or near) the axle out back. Drop blocks won't overcome this interference to get you any lower--you'll need the c-notch for that...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-06-2017, 01:41 PM   #2
staydubbin
You are correct! Hoping to get my notch installed In the next couple weeks! So putting in blocks at this point won't do or help anything ?
staydubbin is offline   Reply With Quote
Old 07-06-2017, 05:07 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: drop blocks
I use lowering blocks to keep the ride height low, with the correct amount of air in the bags.
Keith
Convert to disc brakes.
Old 07-06-2017, 05:54 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Re: drop blocks
What he said
-Chris
Old 07-07-2017, 12:55 PM   #5
SCOTI
SCOTI's Avatar
Re: drop blocks
The blocks also help w/shock travel on trucks using OE placed mounts.
Since the block raises the rear end from its position above the T/A but doesn't alter the location of the shock mounts, you get some additional drop w/o impacting the shocks available travel.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-10-2017, 09:00 PM   #6
dec010974
dec010974's Avatar
Re: drop blocks
Once you install the blocks with a step notch it should look something like this
dec010974 is offline   Reply With Quote
