Old 07-14-2017, 02:09 PM   #1
Ghost's68
Ghost's68's Avatar
Ls3 swap parts list
I just purchased a used LS3 out of Camaro. I'll be purchasing parts in the coming weeks to drop into my 68. I currently have a 5.3 in it now but I'll be selling it soon.
LS3
4L80E
Standalone harness
PCM (unsure which one will work with my combo)
Camaro pedal
Trans cooler w/lines
Oil cooler
Boyd's fuel cell
Fuel lines/filters
Speed engineer LT's
Black widow mufflers
Dirty dingo swap mounts
Upgrades, not necessary for swap
BTR stage 4 cam
Springs/pushrods/retainers
Fast 102 intake w/rails
CNC ported heads
Anything else missing for needed swap?
Ghost's68 is offline   Reply With Quote
Old 07-14-2017, 06:23 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Ls3 swap parts list
I would switch to the 2005+ corvette pedal. It looks almost identical to the 71/72 pedal. Take a look at my 68 S/C build.
Hart_Rod is offline   Reply With Quote
Old 07-14-2017, 08:46 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Yes, lots. The little things add up quick.
Engine mounts/adapters
Driveshaft
Accessory mounts (if needed)
Electric fan/shroud
Gauges or sending unit adapters
Shifter or adapter
Possible battery relocation
Additional fuse box/wiring
Lots of other things I'm probably missing, that's just off the top of my head. Plan, plan, and plan some more, then leave extra time and room in your budget for the inevitable unexpected.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 07-14-2017, 10:23 PM   #4
ls1nova71
ls1nova71's Avatar
You'll need an oil pan too, don't think the Camaro LS3 one will work in a truck.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-15-2017, 09:16 AM   #5
Ghost's68
Ghost's68's Avatar
Thumbs up Re: Ls3 swap parts list
After looking up the corvette pedal, it does look like a better match and appears it has more range then the Camaro. It doesn't have much of a range of motion. They are faulty cheap too. I quickly cruised through that build thread. You got some awesome projects !
Driveshaft
Electric fan/shroud
Shifter or adapter
Gauges will be down the road, I'll be going with A Dakota set. I will be upgrading my radiator with the entropy one with dual electric fans. As far as drive shaft more then likely I'll just either shorten the one piece one I have now or might even order a custom one from the drive shaft shop, depending on budget.
I most certainly forgot about that! I'll add it to the list. Thanks everyone.
As far as the alternator goes, it's currently located low on the driver side, does anyone know if it has to be relocated up high?
