Old 08-08-2017, 12:52 AM   #1
4SFEDZ
Single red wire on top of sending unit?
How does it attach? 85 swb gmc. Not the ground, it's a single wire and kinda looks like it has a little boot over where it attaches.
4SFEDZ is offline   Reply With Quote
Old 08-08-2017, 01:08 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Single red wire on top of sending unit?
which sending unit?
what engine?
Old 08-08-2017, 06:24 AM   #3
4SFEDZ
305 and passenger side. Trying to drop the tank and would rather not just cut it.
Old 08-08-2017, 06:31 AM   #4
mongocanfly
ohhhhh...ok...when you said sending unit I was thinking temp or oil..
Old 08-08-2017, 06:34 AM   #5
cadillac_al
It just pulls off a pin. The rubber boot holds it on. Don't cut it just pop it off. I usually unbolt the ground wire from the frame. It's easier to get at.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-08-2017, 06:34 AM   #6
mongocanfly
unser that boot should be a stud with a nut holding a wire ring terminal...should also be a ground wire that is a blade connector
Old 08-08-2017, 06:44 AM   #7
mongocanfly
gas sending unit
Old 08-08-2017, 11:15 AM   #8
4SFEDZ
I doesn't look like it has a nut on it. Just kinda looks like a pin.
Old 08-08-2017, 11:17 AM   #9
PunishedC10
Some of the different manufactorers make them differently, yours may just have a male pin on the top that a female connection on the wire plugs into.
1964 Coupe Deville(cruiser)
1966 Chevy II Nova 2door Hardtop
1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys
2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s
2000 Trans Am WS6, LS1/T-56, too many mods to list
PunishedC10 is offline   Reply With Quote
Old 08-08-2017, 12:32 PM   #10
mongocanfly
^^^^correct^^^^...mine doesn't but some do
Old 08-15-2017, 10:16 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
The sender has a button to snap on it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-15-2017, 01:51 PM   #12
4SFEDZ
Thanks everyone. It was a button that came off pretty easy. Just wasn't sure.
