heater core
seen that they make a heater core for non a/c in aluminum or brass. which is better? Any body know?
Re: heater core
I'd stick with brass. Its most likely all brazed together. Odds are that the aluminum one has epoxy holding the tanks to the core. The epoxy has a tendency to crack over time.
Re: heater core
Any of the aluminum ones I have seen, the end tanks have squared off corners meaning they don't fit the brackets that screw in to the heater box very well at all.
The factory brass ones, the tank ends have rounded corners to fit those brackets.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
