Old 08-17-2017, 04:59 PM   #1
BRASSHEAD
BRASSHEAD's Avatar
Lowest static drop, Who has it ?
Who has the lowest static drop? It can be bolt on,body drop or anything else just as long as it's static. Shortest distance between the rocker and the ground.
BRASSHEAD is offline   Reply With Quote
Old 08-17-2017, 07:29 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Lowest static drop, Who has it ?
Torsion bars and 3" of travel before hitting inner fenders. Rear was baged now all air.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-17-2017, 08:40 PM   #3
hop sing
hop sing's Avatar
very nice did you use stock spindle or a drop spindle ? torsion bars Rule !!! thx Hop
Save a tree support your local drag strip !!!
hop sing is offline   Reply With Quote
Old 08-17-2017, 09:42 PM   #4
LVPhotos
LVPhotos's Avatar
Just bars no bumpstops right before Portebuilt swap. I would tell all to keep the bars. Cost to rebuild now less than when I got the new on the sceen PB. For 60-62 frame.
Old 08-18-2017, 09:45 AM   #5
scoot_mcgrute
I don't have measurements but I'm running 5.5/7 drop on 275/40r18 tires. It looks like the rocker is around 8-10" off the ground going off of the sidewall height of the tire
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 08-18-2017, 11:12 AM   #6
wjjeeper
wjjeeper's Avatar
I'm running a CPP Grand Slam kit and a 2" block in the rear. Lowest part of my rocker is at 6" off the ground. Bottom of control arms are a different story lol..... 2.5"
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 08-18-2017, 11:50 AM   #7
rvrfoot
5.5/7 dropName:  DSCN0968.jpg
rvrfoot is offline   Reply With Quote
Old 08-18-2017, 12:17 PM   #8
theastronaut
theastronaut's Avatar
I had about 1.5" before the front tire would hit the inner fender. Had to take one of the inner fender bolts out to keep it from shredding the tire.
theastronaut is offline   Reply With Quote
Old 08-18-2017, 12:48 PM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
And that is the weak spot for lowering unless you can modify the front fender area.
Old 08-18-2017, 12:55 PM   #10
rvrfoot
May be a little smaller tire?
Old 08-18-2017, 01:06 PM   #11
theastronaut
The crossmember was too low already, a smaller tire would make it even lower.
Old 08-19-2017, 06:20 PM   #12
scoot_mcgrute
Measured the rocker on mine and it's 8" off the ground
1966 Army Truck
Old 08-19-2017, 08:14 PM   #13
LVPhotos
LVPhotos's Avatar
8-3/4 bumper anf cab mount 235/60/15 or park on wet grass
Old 08-23-2017, 01:37 AM   #14
Lil Loafer
When I bought my truck the front crossmember was about 2 inches from the ground.
Lil Loafer is offline   Reply With Quote
Old 08-23-2017, 10:52 AM   #15
Slik66
Slik66's Avatar
So if you slam the truck, the front inner fender is what hits first?
How is the clearance on the rear with a 5-7" drop in rear?
It's what you learn After you know it all that counts!
Slik66 is offline   Reply With Quote
Old 08-23-2017, 03:44 PM   #16
theastronaut
Depends on tire size. You can run a super short tire and have the crossmember bottom out before the inner fender. It'll look silly with that short of a tire though.
I never had any rear clearance isssues at a 6-7" drop in the rear with a small pipe notch. Lower than that, the pumpkin hits the bed floor before the axle tubes hit the frame (with a notch), so at that point you'll need to raise the bed floor and do a step notch.
Old 08-23-2017, 04:16 PM   #17
rvrfoot
There a picture of my truck post number 7 it's 5-7 drop
Old 08-27-2017, 12:18 PM   #18
txinliner
txinliner's Avatar
ive done a 7/ 6 1/2 on my 65
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
Old 08-27-2017, 12:41 PM   #19
Slik66
Slik66's Avatar
Do you bottom out at all in the front?
