Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Closed Thread
Old 01-30-2017, 06:27 PM   #1
Lowell G
Transmission Conversion
Hello, I need some advise. 1967 Chevy C10, 250 6 Cylinder with 3 speed manual transmission. Going to put in a 383 with a 700r4 automatic transmission. What do I need for a cross member for the transmission? I don't think the current cross member for the 3 speed manual transmission will work, but could be wrong. I want to get this done while I am painting the frame. Thanks.
Lowell G is offline
Old 01-30-2017, 11:59 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Transmission Conversion
You might get some responses if you post this in the 67-72 forum
mongocanfly is offline
Old 02-08-2017, 10:24 AM   #3
396ci
396ci's Avatar
you can use a turbo 350 cross member but the manual one wont work. i had a 350/350 in my 70 c10 and installed a 700r4 and the stock cross member worked fine, it just needed to be moved and i had to drill some new mounting holes in the frame.
not sure if you can use the 6 cyl motor mounts on the v8 install. good luck on your project!
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline
Old 08-17-2017, 06:11 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
The current rear engine mount cross member needs to be removed totally.
The V8 will require new engine mount towers and of course, new mounts.
You will need a rear trans cross member, either from a 350/350 truck or aftermarket...
As you realize, its a lot easier to do all this while the cab is off the chassis.
AussieinNC is offline
Old 08-23-2017, 09:24 AM   #5
alysaasmith
1967 Chevy C10, 250 6 Cylinder with 3 speed manual transmission. Going to put in a 383 with a 700r4 automatic transmission. I don't think the current cross member for the 3 speed manual transmission will work, but could be wrong. I want to get this done while I am painting the frame.
alysaasmith is offline
Closed Thread
