#1 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: HEI issues?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Jul 2015
Re: HEI issues?
If you need more help check this: http://www.crankshaftcoalition.com/w...EI_distributor
From the bottom of the page additional informative links: Resources Spark plug cross-reference Exploded view of an HEI distributor Ported vs. manifold vacuum GM HEI rebuild, install info GM HEI distributor notes, etc. Description of an HEI rebuild Return to: Distributor shaft end play adjustment, above HEI vacuum advance specs GM points-type vacuum advance can specs and info (Lars) Return to: Vacuum advance, above. Crankshaft Coalition wiki articles: Firing orders of various engines. Several articles on valve adjustment Carb vacuum port ID How to install a distributor Determining top dead center How to find the number one cylinder in an engine How to make a timing tape Timing tabs and damper TDC lines SBC Estimating timing chain wear How to make a timing tape Here is another accurate source of info: http://www.hotrodhotline.com/md/html/ignition.php Last edited by toolboxchev; 09-13-2017 at 01:32 PM. |
