Old 09-14-2017, 05:49 PM   #7
In The Ten Ring
Re: Fender Removal
It's easy, once you get it going. I removed both of mine with just a 3/8" ratchet set.
Let's see, you have a total of 11 bolts to remove. The three at the rear are one size larger than the 8 at the front, plus ever how many attach the inner fender to the outer.
You may break a couple of bolts, I did when trying to remove the outer from the inner. If that happens you may have to remove both the inner and outer at once.
In The Ten Ring is offline   Reply With Quote
