Old 09-14-2017, 03:20 PM   #1
slowboy
slowboy's Avatar
Fender Removal
I've searched through this forum for how to remove front fenders on my '72 GMC P/U
and can not find any information on how to do this.
Please someone point me in the right direction on how to remove these.
Thanks,
slowboy
slowboy is offline   Reply With Quote
Old 09-14-2017, 03:33 PM   #2
outfield
Re: Fender Removal
Hi slowboy,
I found this info on the forum a while back, so I'll pass it on.
These two images show how the fenders bolt up to the fire wall. You do need to remove the cowl to get access to one bolt, and the door must be open to get access to a couple more. When you look at the under side of the fender you will see the bolts that attach the inner fender well to. There are a couple more bolts that go into the core support that were easy to find, I don't have an image for them.
outfield is offline   Reply With Quote
Old 09-14-2017, 04:40 PM   #3
slowboy
slowboy's Avatar
Re: Fender Removal
Thanks for reply 'outfield'...
...so can fender/s be removed without removing inner fender/s...just remove cowl and hood?...
Old 09-14-2017, 04:46 PM   #4
outfield
Re: Fender Removal
Yes, you can remove the fender and leave the inner fender in place.
I just replaced my passenger fender and left the inner fender in place. We unbolted the hood hinge and rested the back of the hood on a 2x4 that sat on top of where the cowl was. (by the wiper arm pivot) Then unbolted the fender and removed it.
Old 09-14-2017, 04:47 PM   #5
6768chevylover
6768chevylover's Avatar
Re: Fender Removal
yes, that is correct.
6768chevylover is offline   Reply With Quote
Old 09-14-2017, 05:32 PM   #6
slowboy
slowboy's Avatar
Re: Fender Removal
Thanks for reply guys!!
Old 09-14-2017, 05:49 PM   #7
In The Ten Ring
Re: Fender Removal
It's easy, once you get it going. I removed both of mine with just a 3/8" ratchet set.
Let's see, you have a total of 11 bolts to remove. The three at the rear are one size larger than the 8 at the front, plus ever how many attach the inner fender to the outer.
You may break a couple of bolts, I did when trying to remove the outer from the inner. If that happens you may have to remove both the inner and outer at once.
In The Ten Ring is offline   Reply With Quote
Old 09-14-2017, 08:40 PM   #8
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Fender Removal
Is the bracket, #1 in the illustration, a GMC only thing? My '70 Chevy does not have those
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 09-14-2017, 08:44 PM   #9
In The Ten Ring
Re: Fender Removal
My 1972 Chevy does not. My fender was easy to remove, except that the inner fender had to come off with it, and to do that, I had to cut off the inner from the core support, as it was so rusted the bolts broke the core support and were "free wheeling," and unable to remove.
Old 09-15-2017, 08:10 AM   #10
slowboy
slowboy's Avatar
Re: Fender Removal
I started removing the bolts for LH fender well outside and 2 of them want to just spin. Do they screw into one of those metal clips? I'm wondering if clip came off or broke.
Old 09-15-2017, 10:11 AM   #11
70STOVEBOLT
Re: Fender Removal
There are j-nuts that the bolts thread into (metal clips). You will be lucky if only 2 of them break on you. Most of mine did when I removed the original fender. You can get them at NAPA, part number 665-1052, they come in a pack of 7, or any j-nut for 5/16-18 thread will work. I ended up removing the inner and outer fender together because of this problem, then was able to get the old j-nuts off the bolts.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 09-15-2017, 12:36 PM   #12
In The Ten Ring
Re: Fender Removal
I had the same problem, I think two of the j-nuts broke on me, which is why I removed both inner and outer fenders together.
It's a "job" for a single person but it's do-able for sure. I did it in the tight confines of my garage.
Old 09-15-2017, 03:14 PM   #13
raggedjim
raggedjim's Avatar
Re: Fender Removal
Nope, that's a big truck thing, doesn't apply to c10's
Rg
raggedjim is online now   Reply With Quote
Old 09-15-2017, 03:16 PM   #14
70STOVEBOLT
Re: Fender Removal
Learn something new every day! Thanks for the info Roger.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 09-15-2017, 03:54 PM   #15
slowboy
slowboy's Avatar
Re: Fender Removal
there's one in door jamb at the bottom I can't get to...any suggestions?
Old 09-16-2017, 08:05 AM   #16
slowboy
slowboy's Avatar
Re: Fender Removal
I have LH Fender loose. Seems that either grill, or bumper is preventing me from completely removing fender.
Any help/advice appreciated please.
Thanks!
[don't want to remove anything unnecessarily]
Old 09-16-2017, 03:08 PM   #17
Curtb1971
Curtb1971's Avatar
Re: Fender Removal
Thanks!
You will need to remove the grill as it the outer grill support bracket bolts to the fender. Not sure on the bumper but it might be in the way as well. Also the front headlight harness runs through the LH fender and is held on the fender by (2) harness supports, just need to push the plastic clip out of the holes in the fender.
Hope this helps
Curtb1971 is offline   Reply With Quote
Old 09-16-2017, 04:14 PM   #18
In The Ten Ring
Re: Fender Removal
I just now removed my grill and one fender. (I had to open up some holes).
I think you'll have to remove your grill first as it comes up over the sides of the outer fenders. (Mine is a 1972 Chevy). His is a GMC, does his grill have to come off first?
If so, and you have to remove your grill, follow these steps.
1). Remove front bumper. This is the only place I had to use my 1/2" drive and a long cheater bar. First I soaked the bolts in a break free type of product for a couple of days.
2). Remove grill. You'll likely have to lose the headlight surrounds to access some of the grill bracket bolts.
3). Remove outer fender.
I remember taking off my grill first before a fender but I have a Chevy. What say you guys?
Old 09-17-2017, 10:46 AM   #19
raggedjim
raggedjim's Avatar
Re: Fender Removal
You can pull a GMC fender (or a 67-68 chevy fender for that matter) without pulling the grill because they don't overlap the fender like the 69-72 chevy grills do. I've done it tons of times, but I think I always had the front bumper off.
Good luck, Rg
Old 09-17-2017, 11:21 AM   #20
davischevy
davischevy's Avatar
Re: Fender Removal
The bolts screw into j nuts.
I use a pair of small vice grips to grab them from the back side. It ain't easy, but possible.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-17-2017, 12:08 PM   #21
In The Ten Ring
Re: Fender Removal
I did this on a couple of my broken j-nuts but in the end it just wasn't enough or I could not reach a broken j-nut while the fenders were on.
*Pretty neat about the GMC grill and fender not overlapping.
Yesterday I was cleaning up my garage a bit and FOUND PART OF A J NUT THAT HAD BROKEN OFF. Crazy.
Original poster: just keep taking bolts off and you'll get there, figure it out as you go.
Old 09-17-2017, 02:14 PM   #22
davischevy
davischevy's Avatar
Re: Fender Removal
Take plenty of pictures. You will thank yourself later.
other Larry
Old 09-17-2017, 03:36 PM   #23
In The Ten Ring
Re: Fender Removal
Yes, this!
Also put every bolt you take off into a plastic ziplock bag with a label. I did that and I cleaned up every single bolt and fastener. I ended up using new bolts but only because new ones have a coating on them. I have reused some old bolts but it was easy because I had everything labelled.
I took a ton of pics also but those haven't been that important, you'll remember most everything when you go back, I have at least. I still recommend taking lots of pics as you take it apart.
