#26 |
![]() Join Date: Oct 2009
Re: Wheel Openings Are Different!
Oh I agree with you on that point Lakeroadster - but not many folks are putting 33s on their truck - I felt lucky to find 3o" tall tires in the 75R15's I put on. But yes, with drag slicks or big mickey T's, they would certainly look just about right. Problem is - many of the shortened long beds have much smaller than 33" tires. But they all still look good I believe. I think it's one of those things you'd never notice if someone didn't tell you because either way looks right.
#27 |
I have car A.D.D.
Hope I have the right wheel opening sections coming.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
#28 |
![]() Join Date: Aug 2005
FYI, I measured a LWB arch vs. a SWB arch and found right about 1" difference. Anyone else?
#29 |
These little differences are neat!
As a visual reference the picture below shows a shortbed and a longbed. The measuring scale is of course not to scale but it does clearly show their is a difference in wheel well opening lengths. (Vertical white lines are to show the pictures have been scaled so the cabs are the same length.) ![]() Last edited by lakeroadster; 04-27-2011 at 10:14 AM. |
#30 | |
but the Napco trucks in this vintage was only 133 " w/b and up ron |
#31 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I think it was for proportional reasons.
Nothing to back up my theory. Posted via Mobile Device
#32 |
I'm working on a 66 Chev panel. I'm using pickup wheel opening repair panels. When I held them up to my truck they were about 2'' too long . I ended up taking out 2'' out of the center, they seem to fit good now . Hope this helps.
#33 |
am i confused or is this going against panel=long burb=short theory?
Doug 66 4x4 GMC Suburban 76 4x4 Chevy Shortbed |
#34 |
just to be clear on this ,on my 63 panel do i need a long box quarters or a short box??
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#35 |
1961 crewcab
I am pretty sure panel and sub = short, and 1 ton long panel = long.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#36 |
I guess I should have made myself clearer. The repair panel I used was for a longbox pickup, I couldn't find one for a shortbox. Actually I didn't know until I held it up to my panel that there was a difference. Thats why I took some out of the middle. The panels and subs are different from the wheelwell back, I used parts of a repair panel for 73-87 pickup. In front of that I was able to use part of a rocker panel repair piece. Hope that helps you.. Gord
#37 |
does any body know if they still make a full fleet side panel or is it just sold in a 3 piece sections
#38 |
There is a simple explanation for this. 3/4 ton pickups and 1 ton panels could be ordered with optional 17" and 19.5" wheels. These are large diameter wheels and tires that weren't availabe on 1/2 tons. Extra clearance for tire changes and or installing tire chains.
#39 |
so subsequently did this make a difference in the inner wheel tubs and floorboards?
ron |
#40 |
Everything else is the same, if you ordered a 8' fleetside, 1/2 or 3/4 ton, you will get the same bed. Would not have been worth the extra expense for GM to tool a different bed panel on 8' 1/2 tons fleetsides.
#41 |
#42 |
Somebody mentioned in another post today that usen drop springs pivots the axle forward on the trailing arms. So that's a lot of what we see I bet.
#43 |
I wonder if now that they have shortbed besides available, if they might also make available patch panels with the shorter wheel opening.
#44 |
Thanks that will help!
