Old 09-27-2017, 10:31 AM   #51
padresag
Re: '60-'66 Body On A '73-'87 Frame
Originally Posted by LostMy65 View Post
The point we keep leading back to is; there is no point in using the newer frames. Just use the original frame. There is nothing, absolutely nothing to gain using the newer frames.
If anything, it's bass ackwards to not use the original frame.
Just bolt up the newer crossmember, and be done with it.
Not to mention we should keep the matching VIN's.
must have something to do with trying to prove their manhood!
ron
padresag is offline   Reply With Quote
Old 09-27-2017, 11:38 AM   #52
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by Clrussell View Post
What about in the case of an ls swap into a 61? I'm still researching it all
I wouldn't think it would be much different than putting an LS in a 63-66.
But I did a search and found a few threads on topic:
http://67-72chevytrucks.com/vboard/s...d.php?t=667010
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-27-2017, 12:09 PM   #53
Clrussell
Clrussell's Avatar
Wait I just read this thread title is 73-87 never mind! Lol
61 apache
Clrussell is offline   Reply With Quote
Old 09-27-2017, 12:42 PM   #54
66Z71
66Z71's Avatar
ron
My reason was actually quite simple. 11 years less abuse on the frame and suspension plus disk brakes, power steering, and leaf springs. Only thing required was lift the old cab up, and roll the new stuff under it.
The swap is really quite simple. Bolt the body mounts to the cab, drop the cab onto the frame, weld the mounts to the frame. Done.
Eric
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera
66Z71 is offline   Reply With Quote
Old 09-27-2017, 12:58 PM   #55
padresag
frames are very seldom a problem. most of these swaps are made with boxes on them and most do not alter the w/base to have the tires centred properly which looks a little hokey.
ron
Old 09-27-2017, 02:51 PM   #56
padresag
that is what the guy did to this suburban from page one, just drop thr body on the frame and adapted.
and this was a suburban not just a c & c with a flatdeck
bet he didn't spend that much time on it
ron
Old 09-27-2017, 06:58 PM   #57
argonaut
argonaut's Avatar
"Robust"
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-27-2017, 07:48 PM   #58
Flying Hamster
Flying Hamster's Avatar
ron
Wingnuts???
WINGNUTS!!!
Wow.
2006 Sierra RCSB V6 5 Speed RWD.
Flying Hamster is online now   Reply With Quote
Old 09-27-2017, 08:49 PM   #59
Blue666(2)
The wingnuts allow quick cab removal for easy cleaning.
Blue666(2) is offline   Reply With Quote
Old 09-27-2017, 10:21 PM   #60
Mack B
Mack B's Avatar
Just roll the new frame under.... - done.
I can tell you are pretty passionate about this topic, may I ask why it bothers you so much? Please correct me if I'm wrong, but doesn't your truck have an earlier frame swapped in?
If I desired to own a 4x4 60-66 this is likely the route I would take. If I had a truck with a damaged frame and the only replacement I could find was a later model, I possibly would try this route was well.
The person you are mocking has a good looking truck. From the pictures he provided the work appears well done. I don't understand the disgruntlement in how others choose to build their trucks.
Mack B is offline   Reply With Quote
Old 09-27-2017, 10:38 PM   #61
LostMy65
LostMy65's Avatar
You're right, that was rude of me. I apologize.
For a 4x4, it may be the simplest route.
But for disc brakes and power steering on a 2wd it's best to use one's original frame.
But yes, it bothers me because those who encourage others to do it aren't giving sound advice.
My 65 is on a 62 gmc frame. I did it after I totaled it in the 80's. I was 18 and didn't know better.
Old 09-27-2017, 10:47 PM   #62
Chevyboy02
My frame was wrecked. The entire frame is destroyed. I needed a frame and I found an 83 next door without one spot of rust. Easy decision
Chevyboy02 is offline   Reply With Quote
Old 09-27-2017, 10:51 PM   #63
Mack B
Mack B's Avatar
I can respect that opinion. If ones frame was solid and they only wanted updated suspension, braking etc, there are definitely easier, less intrusive options, but every situation can't be covered under that blanket statement. I'll use this next quote as my example.
The fact you where able to get your hands on that frame is likely the only reason your truck is still on the road today. While not ideal, if I didn't have any other options for getting my truck back on the road besides a frame swap...I'd take it.
In my opinion someone showing others it is possible to get good results swapping frames doesn't constitute giving bad advice.
Old 09-27-2017, 10:52 PM   #64
rvrfoot
Some one did a little rigging there.
rvrfoot is offline   Reply With Quote
Old 09-28-2017, 05:33 AM   #65
LostMy65
LostMy65's Avatar
You guys do realize the point of this thread isn't for those who Need a new frame. It's for those that think it's the easier route for the upgrades the 2 wheel drive guys want. To swap out the original frame for the upgrades isn't a practical route.
Old 09-28-2017, 08:44 AM   #66
Mack B
Mack B's Avatar
You do realize that the information contained in a thread on a public forum can be used for other purposes than those intended?
This thread has been bumped multiple times over the years, each time by people looking for more information, the most recent by someone who admits they have a damaged frame. I don't see where I'm off topic here
Old 09-28-2017, 09:20 AM   #67
LostMy65
LostMy65's Avatar
I surely don't want to get into a pissing match. But I do deserve it.
But for the original purpose of this thread, aligned with what is the purpose for swapping frames, if ones frame is good, there is absolutely no advantage to go to the newer frame. That was the point of my post. Body mounts, frame contour, frame horns, and especially VIN.
But I understand I deserve your method of replies because of my snarky reply to another member.
Old 09-28-2017, 07:13 PM   #68
Mack B
Mack B's Avatar
I'm absolutely not trying to get into a pissing match either, and no you don't deserve it.
We are all here for the same reason and we all bring something different to the table. We need to be able to share opinions, experiences and be able to disagree without it turning ugly....we are better than politicians.
Old 09-28-2017, 07:18 PM   #69
LostMy65
LostMy65's Avatar
Thank you!
My bad.
Old 09-28-2017, 10:50 PM   #70
rvrfoot
Oh boy i thought you almost opened a can of worms man.
Old 10-07-2017, 01:48 PM   #71
karlbenz
I would never swap to a square body frame for 2 wheel drive. 4wd on the other hand, would do it again in a heartbeat
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 10-09-2017, 11:59 AM   #72
LostMy65
LostMy65's Avatar
Back of the 73+ Frame sits at least 3 inches higher than the 60-66 frame. So, if someone wants a 4x4 truck, or it to look like a 4x4, then go ahead with this swap.
Otherwise, one would have to do some frame or cab surgery.
I'm going to start a thread where I overlay different frames with the 63-66 frame along with a greyscale of the cab and such so we can visually see see where things line up or not.
Old 10-09-2017, 06:14 PM   #73
LostMy65
LostMy65's Avatar
Now this is an interesting swap:
http://67-72chevytrucks.com/vboard/s...d.php?t=688570
Old 10-11-2017, 06:12 PM   #74
LostMy65
LostMy65's Avatar
What about our body on a 1999 or newer LS equipped frame?
Old 10-11-2017, 06:27 PM   #75
padresag
this is how the fellow compensated for the frame difference on the back end of this one
ron
