Old 10-01-2017, 01:47 AM   #1
mfm3
Re: How about some pics of Static dropped 60-66
Front: 3" springs and 2" spindles
Rear: 5" springs, 2" blocks, C-notch
Chrome Wheels: 15 x 6 front/back, 215/75, 235/75
White Steelies: 15 x 7 front/back, 235/60, 255/70
mfm3 is offline   Reply With Quote
Old 10-01-2017, 09:16 AM   #2
likaroc13
Rollin' Old Skool
Originally Posted by mfm3 View Post
Front: 3" springs and 2" spindles, 15 x 6, 215/75
Rear: 5" springs, 2" blocks, C-notch, 15 x 6, 235/75
White Steelies: 15 x 7 front/back, 235/60-15, 255/70-15
Looks great!....what color is the truck, a cream or pale yellow? Thanks
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-02-2017, 01:44 AM   #3
mfm3
Cool Vanilla...a Chrysler color
Old 10-02-2017, 08:38 AM   #4
likaroc13
Rollin' Old Skool
More of a beige...not an original color.
Cool...looks good!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 01-27-2018, 09:47 PM   #5
67pete300
Front: 2.5" drop spindles and 1" drop spring
Rear: 3" drop spring. Had a 2" drop block in there at first but it was too low.
67pete300 is offline   Reply With Quote
Old 01-27-2018, 11:09 PM   #6
russellrox
Your setup is similar to mine, I’m going to be running 3” rear drop springs and 2.5” drop spindles with stock springs.
russellrox is offline   Reply With Quote
Old 02-08-2018, 11:48 PM   #7
Cris
Just put the new wheels on today (posted under Tire/Wheel pics as well). 1963 C10, dropped 6" in the rear with ECE springs, lowering shocks, and relocation kit. Stock rear bump stops were cut about 3/4".
Front is dropped 4.25" by using 2" drop ECE springs and cutting one coil off. I replaced the bump stops in front with Energy suspension parts. I used longer bump stops up top (Energy suspension part 9.9143R) so when the car is jacked up the springs do not come loose. The lower bump stops (Energy Suspension 9.9101R) are cut to give adequate clearance. This allowed me to leave the drum brakes in place.
Tires are 275/55-17 on 17" x 9" wheels.
Cris is offline   Reply With Quote
