#1 | |
Rollin' Old Skool
Re: How about some pics of Static dropped 60-66
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
![]() Join Date: Feb 2013
Cool Vanilla...a Chrysler color
Rollin' Old Skool
Front: 2.5" drop spindles and 1" drop spring
Rear: 3" drop spring. Had a 2" drop block in there at first but it was too low. |
Your setup is similar to mine, I’m going to be running 3” rear drop springs and 2.5” drop spindles with stock springs.
Just put the new wheels on today (posted under Tire/Wheel pics as well). 1963 C10, dropped 6" in the rear with ECE springs, lowering shocks, and relocation kit. Stock rear bump stops were cut about 3/4".
Front is dropped 4.25" by using 2" drop ECE springs and cutting one coil off. I replaced the bump stops in front with Energy suspension parts. I used longer bump stops up top (Energy suspension part 9.9143R) so when the car is jacked up the springs do not come loose. The lower bump stops (Energy Suspension 9.9101R) are cut to give adequate clearance. This allowed me to leave the drum brakes in place. Tires are 275/55-17 on 17" x 9" wheels. Last edited by Cris; 02-08-2018 at 11:55 PM. |
Hi, here's my '63 longbed :
Cut coils in the front, i dont know how much. 1"3/4 lowering blocks on the rear. Front tires are 235/60R15 and rear 255/60/15. I would like a little more lower but stance not so bad like that. what do you thing about it ? |
