Old 10-03-2017, 09:34 PM   #4
obijuan
Re: Trying not to get carried away on front end rebuild
I wouldn't. It's two totally separate systems. Are the ball joints loose? Irregular tire wear? Moog ball joints wear prematurely. I suggest genuine dana spicer. But only if they need it.
Don't overlook the steering box mounting at the frame. They tend to crack at the bolt holes for the steering box. Also if it's lifted without caster correction that will cause driftiness. 5-7 degrees is ideal.
If its lifted are your spring bushings ok? Upper shackle hanger bushings often go unchanged with lift kits. Energy suspension offer poly replacements.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
