Cordless Impacts
With the age of our beloved prefect in every way trucks. What are y'all using to convince hardware that hasn't been removed in the past 40-50 years to break loose? I have a decent air compressor that can run air tools but it is god awful loud. I have an air ratchet, 3/8 impact, and a 1/2 impact. However, they all need a tune up. They leak air and because of the leaks aren't as powerful as they should be. They are all pretty old. They were my dad's when he worked on the flight line at Bergstrom AFB.
With that being said I am thinking about getting a 3/8 impact that is battery operated. Hell, I'd settle for a corded one asst this point. Looking for suggestions. Thanks in advance. |
![]() Join Date: Mar 2013
Re: Cordless Impacts
I've got this one (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and I love it. Nice to have on smaller jobs. Has a ton of breakaway torque as well.
Faced with the same dilemma recently I went with Pneumatic replacement for my age-old and failed 1/2 air impact.
I purchased this: Ingersoll Rand Air Impact Wrench 1/2in. Drive, 4.2 CFM, 600 Ft.-Lbs. Torque, Model# 231C ..and so far have found it to be the real deal. No fake torque spec or over exaggerated claims. Just solid performance. It was on sale, if I remember right I got it for around 100 bucks in the store locally in Dallas. https://www.northerntool.com/shop/to...ct_17802_17802 It's 115 right now on Amazon. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
I have a set of Milwaukee m18 fuel impacts.Since buying the 3/8 and 1/2 ,I never use my air impacts. These things are awesome.
![]() Join Date: Jul 2000
This one has served me well for 3-4 years, but I've never used it on really nasty rusted bolts. And it doesn't have as much torque as a 1/2" drive air tool.
As you can see a little lower on the webpage, you can buy a kit with 2 batteries & charger, or the bare tool only. Since I already had a Bosch drill that uses the same batteries, I bought just the "bare" impact driver on Amazon. My lithium ion batteries are 6-7 years old and still hold a charge for a very long time. Both the tools and charger are first rate. https://www.boschtools.com/us/en/bos...h181-144417-p/ ![]()
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
x2 for Milwaukee fuel stuff. I have not used my IR 1/2 air impact since I got the Milwaukee 3 years ago
#7 | |
![]() Join Date: Jul 2016
In the past few months I almost exclusively use a Milwaukee M18 1/2" impact, its kind of heavy and large but it is as strong as any air impact I have ever used. Kind of spendy but can be found on offerup or craigslist reasonable.
If your air compressor is noisy I would fix that first...put it outside, build an enclosure if needed, put it in the basement, build an enclosure around it, something. Its the first thing I did with my compressor. |
#9 | |
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
I used the Milwaukee fuel 1/2 drive to rebuild my front in at my friends shop. it worked so good I decide to buy a 1/2 drive for my self, all my cordless drivers and drills, led lights ect are Makita. I have 5 battery pack so naturally I buy a Makita. to be honest I should have bought the Milwaukee seems to have more torque.
X2 on the Milwaukee stuff can beat it. But sometimes still need a big air impact. Last time I used my air impact was on a dmax harmonic balancer bolt. But I takes close to 400lbs to get them off. But the cordless does the rest.
Go Pack Go!
Milwaukee battery powered, can't go wrong.
I'll probably get a lot of slack for this, but the Harbor Freight electric impact wrench is a beast! I've taken apart my front suspension, rear bed and many other rusted bolts and it has performed flawlessly. $40 (with coupon of course) is hard to beat.
![]() Join Date: May 2012
ancient 1/2 pneumatic I've had forever... no need to toss every two years for the latest battery model, it get's em loose most of the time. If that don't get it loose, I have a 3/4" breaker... If that don't work I have a cheater for the 3/4" breaker. If that don't work... I get mad!
White K20 |
#15 |
Active Member
![]() Join Date: Jun 2016
Do you mean the corded 1/2" one? I always figured it would be lousy and never tried. Just got their new 3/8 cordless ratchet and its been pretty handy.
David Larsen 1970 Chevrolet C-10 |
#16 | |
#17 | |
All about them Ks
![]() Join Date: Jun 2014
That being said dewalt has some real good 20 volt stuff as well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
#18 |
![]() ![]() Join Date: Sep 2008
I have Ridgid cordless tools, including 3/8 impact. I have nothing bad to say abut them.
I don't know about the others, but Ridgid has a lifetime warranty if you register them. You must register them. All you have to do is take the problem tool to an approved service center and it's repaired or replaced.
#19 |
![]() Join Date: Feb 2014
I use milwaukee fuel 3/8" for sheet metal bolts and the big dog 1/2" for lugs, cab mounts and chassis stuff. Never had to bust out air impact since buying the 1/2" plus I like the fact of not dragging an air hose around.
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
#20 |
Cordless is dominated by the Milwaukee M18 Fuel.
Should be some bargains soon because they're updating their product line about now. Make sure you get the M18 Fuel line. They have 3 levels of technology/performance. M18 (brushed), M18 brushless, M18 Fuel (also brushless). |
#21 |
![]() ![]() Join Date: May 2015
I have snapon battery impacts...we had them at work and if a tool could ever be abused we could do it...we probably use them more in a weeks time than a normal person could use in a year..we used them for years..I likedm so much I got on ebay and found a slightly used one for $200...work was paying around $600 for them...then snapon changed the design and they arnt worth a bucket of mud....now we have ingersalls...and wow they're a beast...so if mine ever gives out ill be shopping for snapon....
#22 |
#23 |
Thanks for all the insight. Any of y'all ever repair your own pneumatic tools?
#24 |
I have a snap on cordless impact that's about 9 years old. Works fantastic. I did have to get a couple new batteries last year(ni-cad). Other than that its been trouble free other than a lock ring hear and there.
#25 |
