Old 10-24-2017, 11:39 AM   #1
saxart
saxart's Avatar
Starter Question
I ordered a new starter for the 350 SBC in my '70 C-10 and had a quick question. Based on a search of the forum, I went with a mini-starter for a 2003 Silverado 3500. (This engine has the SM465 transmisssion and 168-tooth flywheel.)
Anyway, when the new starter showed up it looks like it has 11-teeth on the bendix gear, while the old starter has 9-teeth. This doesn't seem right to me, but I'm hoping others have had some experience with this and can shed some light. Will this starter work for my set up? Any thoughts are appreciated.
Thanks!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 10-24-2017, 08:48 PM   #2
Mike C
Mike C's Avatar
Re: Starter Question
What flywheel is in your truck? I think you need to find one with 9 teeth on the bendix.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-28-2017, 12:02 PM   #3
saxart
saxart's Avatar
I've got the 168-tooth flywheel.
Any additional thoughts here?
Old 10-28-2017, 05:19 PM   #4
ratty69
According to this, 9 and 11 tooth starters are interchangeable.
http://www.remyautoparts.com/The-Lat...PG-%28PG260%29
ratty69 is offline   Reply With Quote
Old 10-28-2017, 05:38 PM   #5
hjewell2
hjewell2's Avatar
Yes both gear teeth count will work on a 168 tooth flywheel.
hjewell2 is offline   Reply With Quote
Old 10-28-2017, 07:25 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
The 11 tooth drive will have a smaller mechanical advantage than the 9 tooth drive, but it should work unless you are running huge static timing, like 13:1 or something.
~Steven
Simi Valley, CA
Old 10-28-2017, 09:50 PM   #7
saxart
saxart's Avatar
Sweet.... This is the info I was needing to hear. Thanks!
Old 10-29-2017, 01:26 AM   #8
dflarsen77
Active Member
What model should I look for to get the 9 tooth?
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
