Old 01-10-2018, 10:03 PM   #1
69ls4.8swap
air conditioning and fuel tanks
I have read thru some great threads and have gained a ton of knowledge, sometimes too much, on swapping to a 4.8 lq4 engine. I'm sorry if i have overlooked a thread on this. My 69 c10 is an ac cab truck and the 4.8 i am installing has a brand new ac compressor that i would like to reuse. I'm not in a position to put a retro system in and am wondering if anybody has used the ac pump from a ls to work with the 69 ac box. The ac worked great before i removed the 350 and i have capped all the lines and fittings so no moisture would enter.
Also I want to move the gas tank under the bed between frame but have the fuel fill come out behind license plate like on my 70 chevelle, and install a flip down plate. Any body make some suggestions with sender and intake fuel pump?
Thank you in advance.
69ls4.8swap is offline   Reply With Quote
Old 01-11-2018, 01:17 AM   #2
GMC-YA68
GMC-YA68's Avatar
Re: air conditioning and fuel tanks
4.8 = LR4
5.3 = LM4
6.0 = LQ4
I think lol
People have done what you are wanting and will chime in. It’s tedious work, custom made fittings/hoses etc.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 01-11-2018, 01:44 AM   #3
Killer Bee
Killer Bee's Avatar
great source of info on the LS engine platform..
https://ls1tech.com
good luck!
Old 01-11-2018, 11:38 AM   #4
Jrgunn5150
You can use the newer pump with the older factory AC components.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 01-11-2018, 12:48 PM   #5
69ls4.8swap
Sorry gmc. Stupid auto correct. Thanks. I have a guy who makes lines for a living so that's no biggie. Seeing as old compressor only had 1 wire newer one had 6 I think
Old 01-11-2018, 12:56 PM   #6
Jrgunn5150
The PCM can control the newer AC, on/off, dile high, high speed clutch etc. Or you can wire it standalone.
J.R.
