Old 04-26-2004, 08:03 PM   #1
aggiedave98
replace pittman arm and idle arm??
I'm putting in a lift kit and plan on replacing the following:
ball joints
tie rod ends
should I also replace the idler arm and pittman arm while I'm in there?? It's only about an extra $70-$80 for both. I don't want to replace if it makes no sense, but since I'm in there it would be easy to.
btw, it's on an '89 suburban 2wd with 115k miles on it.
aggiedave98 is offline   Reply With Quote
Old 04-27-2004, 01:08 AM   #2
68step
Ya I would replace them but the pitman arm is a PITA you have to unbolt the steering box and swivil it back to get a puller on it.
95 sfa 38.5 swamper TBI vortech
68 chevy stepside
68step is offline   Reply With Quote
Old 04-29-2004, 05:08 PM   #3
COBALT
COBALT's Avatar
I was able to yank my pitman pretty easy on my truck, but of course it's a '69. A Puller and patience is all that was required.
To answer your question I would replace them. Both have greasable joints just like your tie rods and ball joints. Might as well start off with a good steering system.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
