Old 03-14-2018, 05:53 PM   #1
nyncompute
nyncompute's Avatar
Power steering pump rebuild / reservoir removal
I want to rebuild my power steering pump and thus retain the original canister with its original look and hose orientation. Problem is the dang thing will not release from the body. I tried to gently massage it off with a rubber hammer but no go. Also tried a bit of heat...nada.
If I get to aggressive it will start to dent as it has fairly thin metal. Any tips?
Oh and yes the bolts are all off
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 03-14-2018, 06:04 PM   #2
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Re: Power steering pump rebuild / reservoir removal
You did remove the pressure regulator right.
CaptRMW is offline   Reply With Quote
Old 03-14-2018, 06:05 PM   #3
harpo231
harpo231's Avatar
Clamp the iron snout of the pump into vise and go around the reservoir gently hitting it with a small rubber hammer , try to always hit it on the outer part where the front and side of the reservoir are folded together . Patience and plenty of penetrating oil are your friends ....
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-14-2018, 09:40 PM   #4
nyncompute
nyncompute's Avatar
I did that and it started to distort..Thanks for the tip . Out to the garage for another try
Old 03-15-2018, 12:57 PM   #5
original-71
///Relaxed Atmosphere
original-71's Avatar
lay it with the internal side facing down in the vice and the outer canister facing up and try to tap it through the holes were the bolts were with a screwdriver or punch and rubber hammer. that's how I did mine
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 03-15-2018, 07:23 PM   #6
franken
You did remove the big fitting that the pressure line runs to right? The res is sealed by a giant O-ring to the pump and that's all that holds it on once everything us removed from the back. For grins, I checked one lying around and the fitting takes a 1" socket...
