Old 03-16-2018, 10:36 AM   #1
WarMonger
WarMonger's Avatar
Crossmembers and Airbags
Getting close to getting the rear bag set-up done. We did some mock up work and looks like my drive line is going to hit the crossmember frame support. In your guys opinion, should I modify this one or do you know of a new center support that has more clearance? See pic with red arrow
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 03-16-2018, 01:49 PM   #2
demian5
demian5's Avatar
Re: Crossmembers and Airbags
You may have to make one.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-16-2018, 03:26 PM   #3
67c10rustbuket
67c10rustbuket's Avatar
That crossmember wasnt used on short beds so now that you’ve shortened the frame just remove it.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 03-16-2018, 03:48 PM   #4
Rufas
Rufas's Avatar
My drop isn't a much as yours. I had to notch about 1/2 out of the cross member. So far so good...
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 03-16-2018, 03:55 PM   #5
WarMonger
WarMonger's Avatar
That's what I was thinking also. thanks
1970 C20
-_--_--_- ______
1972 K5
Old 03-17-2018, 09:24 AM   #6
Hart_Rod
Hart_Rod's Avatar
Looks sweet! Are you raising the bed floor?
Hart_Rod is offline   Reply With Quote
Old 03-17-2018, 10:31 AM   #7
WarMonger
WarMonger's Avatar
I was planning to, but I left this one in and cut a section for the C-notch. That way I can mount the tank and compressors upfront and the gas tank in the rear. I think I will either put a new metal one in that is raised or a wood one.
1970 C20
-_--_--_- ______
1972 K5
Old 03-17-2018, 10:34 AM   #8
WarMonger
WarMonger's Avatar
I think I will leave the crossmember in for strength. I will use a piece of 6" pipe and weld it in the center of the member for clearance. Well..... that is the plan so far.
1970 C20
-_--_--_- ______
1972 K5
Old 03-17-2018, 01:19 PM   #9
Hart_Rod
Hart_Rod's Avatar
Sweet! Let me know if you need some of my shortened rear tubs.
