#51 | |
The Older Generation
Re: 6L80 4WD to 2WD
OK, thanks. LockDoc
#52 | |
![]() Join Date: Dec 2012
Re: 6L80 4WD to 2WD
Any updated? How did this work for you???
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!!
#53 |
Re: 6L80 4WD to 2WD
Great thread here First c10. I have a couple of questions for you.
Any idea what kind of HP this drive shaft would be good for? What would be the limiting factor, or the "weak link" in your opinion? I realize there is virtually no slip from the transmission output shaft to the center support bearing, but what about the rear portion of the drive shaft? I didn't see any pics of that. Thanks, Bret |
#54 |
![]() Join Date: Sep 2012
Re: 6L80 4WD to 2WD
subscribed
great thread
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
#55 | ||
Re: 6L80 4WD to 2WD
Hey Heliarcn, sorry for the late reply as I didn't see it till today....
the truck has probably close to 400 hp now and we haven't had a problem since we did it a few years back. Weak link??? Maybe that it is a 2 piece drive line with a center carrier bearing... probably has 20K miles on it by a young driver 16 now 18 and the 2nd set of tires and "knock on wood" no problems.. Quote:
Thanks Brian Quote:
#56 |
Re: 6L80 4WD to 2WD
Is the 6L90 trans the same as the 6L80 to swap out the tail housing? I have a 6L90 and I did buy the 2wd tail housing for it, but I was hoping not to tear into the trans to replace to tail shaft. The whole trans has to come apart to replace the tail shaft and there is 2 different ones that it could possibly be.
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. |
#57 |
Re: 6L80 4WD to 2WD
Did you ever measure all of your drive line angles? Great info btw, thanks.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
#58 | |
Re: 6L80 4WD to 2WD
I added a 4* shim to actually rotate the pinion up. Since the truck was lowered Tk- I do believe the tailshaft housings are the same but the spline count on the output shaft are different. 6l80 is like a th400. 32 spline and 6l90 is like 29 spline. But not 100% sure. If I had to do again I would not have removed the rear seal and pulled the plugs. I would have just lubed up the shaft and spline as it doesn't move. But other than that it runs fine.
#59 |
Re: 6L80 4WD to 2WD
Well I will definitely need a slip yoke as I am running air ride. The camaro shaft looks like it would work but probably a little over my budget. Stuff like like is hard to find in canada and if you do find it they want an arm and a leg for it.
#60 |
Re: 6L80 4WD to 2WD
This is a two piece drive line. If you plan to use a 1 piece drive line it may not work as you only have about 3" of spline in the 4wd trans tailshaft the reason mine does not slip is because the front drive line has a carrier bearing that does not move in and out. It's the rear driveline that moves in the spline of the front driveline. Check out the pictures earlier in the thread.
#61 |
Re: 6L80 4WD to 2WD
Mine is a one piece shaft. The truck is a shortbox stepside.
#62 |
Re: 6L80 4WD to 2WD
So bumping this for info.
Im following but also a little confused. Basically looking a dropouts for my 57 panel (2WD) with 4WD trans (4l60/4l65e/4l80e/6l80e) as there are many more options and easier to find as they were more common. I read on some threads and some guys talk about switching out tail housing from a 4WD with a 2WD. But from what I can tell ..... seems like ALL of these transmissions requires that the output shaft be removed (shorter 4wd) to a longer 2WD. Basically a full tear down. So this is false ? Are there any ways to bypass a full rebuild on any trans -- this seems like one way ... but requires a 2 piece drive shaft. Since I dont have a drive shaft and likely will have to get one made ...... could this be an option ? I saw someone mention a drive shaft with the slip "built in". IS this another option ? thx
FAKKY 57 PANEL BUILD |
#63 | |
Re: 6L80 4WD to 2WD
Hello Fakky,
Ok I cannot confirm but the 4L series transmissions will need to have the tail shaft and tail shaft housing replaced. On the 6L series 4wd you will need a 2 piece driveshaft unless you change out the tail shaft to a 2wd. As the 4wd does not have much spline to move in and out. If you want to use a 1 piece drive shaft with a slip built in the driveline you will have to figure out how to attached the yoke to the transmission. Like have the 4wd tail shaft drilled and tapped to accept a bolt to secure the yoke to the trans. Not sure your suspension set up but if the truck is lowered maybe the overall travel (compressed to full rise) will not cause the drive line to move much in and out to cause a problem. The 2 piece drive line uses the carrier bearing mounted rigid so it does not travel in and out at the trans. Hope this helps. Scott Quote:
#64 | ||
Re: 6L80 4WD to 2WD
Most guys talk about swapping tailhousings ...... but thats seems more to me for the VSS and physically housing the longer shaft once you remove the Transfer case adapter. But you still need to tear into. ?? Quote:
Im not really worried about a 1 or 2 piece driveshaft. As either way the chances are its going to be custom due to 57 truck with 8.8 explorer rear axle - guessing not many drivelshafts will bolt straight up. So - on the 6l80e ..... 1) Is there no VSS on the outputshaft/tailhousing ? So not a concern like the 4lxx series ? 2) Do all 4lxx series have VSS on the output shaft - looks like maybe the 4l60 doesnt but the 4l80 does ........ but still ..... seems both need full dissasembly. 3) MY truck had a single driveshaft. I assume I can convert to a 2 piece custom driveshaft with carrier bearing - just need a way to mount the carrier bearing. If I went this way then technically could follow the same modications you came up with here ? Seems a little confusing on which trans require exactly what modifications to convert to 2WD from 4wd. But from about 6 hours of research this is where I am at currently. thanks !!
#65 |
Re: 6L80 4WD to 2WD
--- update
=====4lxx series So did more research. Pretty sure on the 4l60e =>4l80e you cant just swap out tailhousings. You do effectively do a tailhousing swap .... but it requires replacement of the output shaft to a longer output ... and that is held inside the transmisison as an essaembly with a snap ring. The kit would like like this .... https://www.ebay.com/itm/261775210599?ul_noapp=true But required outputshaft replace so have to get inside. On the 6l80e series I havent looked yet ..... assume its similar. So this idea is still intriguing to prevent that. BUt ... How do you add a custom 2 piece driveshaft to the trucks. do you just fabricate a carrier bearing "holder" and thats about it - or more to it. Im thinking ots probaby not worth it - makes sense on original C10 when re-using 2 piece shaft as the costs would be $40-$80 for 4l80e yolk $80-$120 for rear short tailhouse $custom driveshaft and fabrication of carrier support etc So -- not as bad as rebuild but for the effort and the non-standard appracoh in other trucks without a stock 2 piece DS ..... think Ill probably keep hunting for a 2WD.
| Bookmarks |
