Old 11-19-2016, 05:45 PM   #901
Mikeextrafast
Re: How about some pics of bagged 60-66
Mikeextrafast is offline   Reply With Quote
Old 11-19-2016, 07:09 PM   #902
LVPhotos
LVPhotos's Avatar
1962
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-02-2017, 03:43 PM   #903
RAYDAY
RAYDAY's Avatar
sold now but until last june this was mine!
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline   Reply With Quote
Old 01-02-2017, 08:53 PM   #904
steveb64
steveb64's Avatar
Finished up my air valve install.
steveb64 is offline   Reply With Quote
Old 04-25-2017, 04:07 PM   #905
rocket_customz
rocket_customz's Avatar
My 66 that im building. First time seeing the cab on the frame
1966 Chevrolet
5.3L LM7, cammed, ported and polished
4l60E, manual valve body
Throbros front dropmember,Custom 2 link rear with watts link
Ridetech control arms, Accuair air management
rocket_customz is offline   Reply With Quote
Old 12-26-2017, 09:04 AM   #906
Beatrice
Beatrice's Avatar
my 63'. trucks on choppin' block front with my own setup in the rear.she's a garage queen for another 6 months (hopefully)
Beatrice is offline   Reply With Quote
Old 12-26-2017, 10:36 AM   #907
Backpayne
How loud are manual valves? I've thought about using them instead of the others.
Backpayne is offline   Reply With Quote
Old 02-10-2018, 01:39 PM   #908
SkinnyG
SkinnyG's Avatar
Yes, please - how loud??
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 02-10-2018, 02:41 PM   #909
Backpayne
Me, too! I've heard that if you run exhaust tubing from manual valves to the exterior it's quiet in the cab.
Old 02-11-2018, 08:39 PM   #910
1968C30
1968C30's Avatar
My 64 hoping to drive by summer
1968C30 is offline   Reply With Quote
Old 02-11-2018, 09:39 PM   #911
Jferrante
Jferrante's Avatar
nice whats the details on it?
Jferrante is offline   Reply With Quote
Old 02-12-2018, 06:01 PM   #912
1968C30
1968C30's Avatar
Manual air ride,400 small block with turbo 400,4 wheel disk brakes.275/55R20 on rear and 245/45R 20 on front. Thanks
Old 04-07-2018, 12:03 AM   #913
60apache
60apache's Avatar
Originally Posted by Miayota View Post
what did you do on the rear suspension? got any pics inside of the bed?
60apache is offline   Reply With Quote
Old 04-07-2018, 04:41 PM   #914
Hack_Attack
Hack_Attack's Avatar
I've run these little silencers on dump valves before.......so quite, you hardly hear the air when you lower your truck.
Hack_Attack is offline   Reply With Quote
Old 04-11-2018, 09:58 PM   #915
Bringit187
Are you guys doing drop spindles and cups in the front. What is your ride height. I'd like.to.keep.my ride height close to where it is now with my 5 and 6 static drop
Bringit187 is offline   Reply With Quote
Old 04-12-2018, 07:54 PM   #916
robber grin
62 Short Fleetside static dropped 5 1/2 x 6 - floor channeled 3" inside the bed box - stock 62 chassis with 78 front clip
Hope to be converting to a basic Air Ride System soon, since I have sufficient pavement samples for my research work...
when taking measurements and looking for hiding places to stuff equipment I found that I have 3" inside the c-notch to the bump-stop, but my rear tire is about 1-2" from inner bed side and will definitely hit when I drop it on bags.
73 K10 12 bolt posi rear is slightly wider than original so I'm guessing I have to trim inner bed panel or change wheel offset.
Anyone else encounter such doings???
Too much talent on this board to ignore
robber grin is offline   Reply With Quote
Old 04-13-2018, 09:33 AM   #917
robber grin
did you have to massage the inner bed sides to clear the tires?
What about up front? Inners cut out too?
Nice ride...
Old 04-13-2018, 11:29 AM   #918
forestb
forestb's Avatar
Miayota is that your green truck? Man I love that thing.
forestb is offline   Reply With Quote
Old 04-14-2018, 04:56 AM   #919
1968C30
1968C30's Avatar
Nice ride...
Thanks, I removed the front inner fenders. Had to trim the front fenders also. I also had to trim the bedsides and the fender well lip.
Old 04-26-2018, 11:37 AM   #920
Android04
Android04's Avatar
My 1965 C10 - newly bagged and finally on the road. Paint coming soon...
Android04 is offline   Reply With Quote
Old 07-31-2018, 12:40 PM   #921
bpope
Got mine on the ground, finally. Still haven't done the c notch yet. I will probably tackle that when it cools off some. I have a few things to finish before I drive it.
bpope is offline   Reply With Quote
Old 05-05-2019, 12:05 AM   #922
Slappyracecars
Few pics of my 66
Slappyracecars is offline   Reply With Quote
Old 03-22-2020, 10:21 AM   #923
lowroder
how did the crossmember swap go whats the details..? also what tire size are you using in your photo
lowroder is offline   Reply With Quote
Old 03-22-2020, 10:23 AM   #924
lowroder
im interested in some 62s that has been bagged.. either crossmember swap or on stock suspension doing the torsion bar delete
Old 03-23-2020, 04:24 PM   #925
nhtc33d
Some pics of my 60 GMC long bed (slowly being turned into Chevy) project.
I removed all the X frame stuff from the 60 chassis, Z'd the front frame,made and installed a step notch and shortened frame and bedsides. It will be getting a 377 sbc and a 4 speed tranny.
The maroon 65 c10 was bought as a parts truck for this project. The frame of the 65 c10 already had a step notched installed as well as a pancaked front crossmember and an aftermarket trailing arm mount when I bought it. I will be selling most of that stuff and several parts from the GMC.
My build link.. http://67-72chevytrucks.com/vboard/s...d.php?t=285353
nhtc33d is offline   Reply With Quote
