Old 03-30-2018, 09:58 PM   #1
VOoDoO70
truck fires but wont idle
The trucks been sitting awhile for close to a year, truck will crank over but wont idle and Im stumped. Heres the setup 1970 C10 sbc( not stock) with an electric external fuel pump mounted on the frame, coming from an in cab tank, to a 600 Edelbrock carb. No fuel pressure regulator. When I turn the ignition the fuel pump starts humming and shows 6.5 psi on the gauge in the fuel line, then I crank it fires right up but you have to keep your foot tapping the pedal to keep it running. I noticed the fuel filter by the carb does not fill up. As I mentioned the truck has sat for awhile but I since then have replaced the carb with a brand new one, and drained out all the old fuel from the entire fuel system. I even blew the metal line and fuel pump with compressed air. I feel like Im missing something, but dont know what else to look for. This is my current fuel system. Any imput?
VOoDoO70 is offline   Reply With Quote
Old 03-30-2018, 10:11 PM   #2
phat69
Re: truck fires but wont idle
The the fuel line off the carb and see how much it flows. You should rewire that pump. solder the connection or at least get the butt splices with the heat shrink. If your 12+ wire is smaller than the lead coming out of the pump it should be replaced with at least the same gauge.
phat69 is offline   Reply With Quote
Old 03-31-2018, 08:51 AM   #3
aerotest
Idle jets are probably gummed up.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust)
aerotest is offline   Reply With Quote
Old 03-31-2018, 10:36 AM   #4
Coley
Coley's Avatar
So hang on a second.....
The fuel filter that does not fill up....is not by the carb based on the pics, its down in front of the block right?
Now, the pressure gauge which Is by the carb ends up showing 6.5 psi right?
Try disconnecting the fuel line from the upper gauge (near the carb) and run this into a bucket or gas can and see if the pump starts to fill it up and how consistent the flow is.
I would start with that.....simply troubleshooting.
My two bits.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 04-18-2018, 08:05 PM   #5
VOoDoO70
My two bits.
Coley
Yes the fuel filter is down in front of the block, I disconnected the hose right before the fuel gauge going to the carb and ran it into a gas can while I turned on the fuel pump. The fuel pump is NOT the problem it's getting plenty of fuel going to the carb. The carb is spitting fuel as it should when you rev the engine, just cant get it to idle. I tried adjusting the carb mixture screws and idle screw but no change. I feel like it has to be something simple. What else could be the culprit?
Old 04-18-2018, 08:12 PM   #6
Greasey Harley
Greasey Harley's Avatar
Check for vacuum leaks?
Greasey Harley is offline   Reply With Quote
Old 04-18-2018, 08:26 PM   #7
rockyrivermark
Too much fuel pressure. Very common prob on edelbrock and brought up here last month.
Get pressure regulator and reduce to 5 psi.
I'd bet that fixes it.
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 04-18-2018, 08:35 PM   #8
WorkinLonghorn
WorkinLonghorn's Avatar
I'll tell you one thing. If you ever have that v-belt break, there is a good chance that that little plastic see-through filter will be shattered and you will have a major problem. I once bought a car with this set-up and about a month later the belt snapped and broke the filter and my car became a freeway fireball. If they had YouTube back then I'm sure I would have been a star. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 04-18-2018, 08:38 PM   #9
rockyrivermark
Read this thread. Same prob you have
Many didn't believe that it was a fuel pressure problem but that's exactly what it was
6.5 is too much pressure even though edelbrock specs say 6.5 is max.
http://67-72chevytrucks.com/vboard/s...d.php?t=759963
My build page
Old 04-20-2018, 03:11 PM   #10
VOoDoO70
Ok update I relocated the fuel filter out of harms way added a fuel pressure regulator and for some reason it does not change the pressure shown on the gauge. The gauge is steady at 6.5psi even adjusting the allen screw up or down while the fuel pump is on priming. I can't get the motor to stay on to adjust the regulator at idle. Also as I try and keep the motor running it will die and spit fuel out of the top of the carb. WTF!
Old 04-20-2018, 04:56 PM   #11
rockyrivermark
Definitely have to get the pressure down
When at idle do you see gas flooding in the carb?
My build page
Old 04-21-2018, 06:53 PM   #12
VOoDoO70
I took the carb apart checked the floats they are good, cleaned the screens behind the needle and seats everything is good. The carb was actually clean since its brand new. No flooding in the carb just cant get it to run on its own.
Old 04-21-2018, 07:03 PM   #13
7 Devils
7 Devils's Avatar
If you rev the motor up off idle and hold throttle position will it stay running at sat 1800 rpm?
Forgive my typos, big fingers and little Android digital keyboard....what a mess
06 GMC Sierra crew cab Z71 DD leveling kit, 34's, bumper, LED lighting. Still doing stuff to it.
67 El Camino Custom 300 Deluxe. In progress.
55 GMC 371 2 1/2 ton. Upcoming project.
7 Devils is offline   Reply With Quote
Old 04-21-2018, 07:09 PM   #14
Aberdare
Aberdare's Avatar
This is old school... so check the following:
1) Choke not closing properly. Adjust choke if necessary.
2) Big vacuum leak on engine somewhere. Use vacuum gauge to check. Fix the leak. You may have put the base gasket on wrong or it is the wrong one for this carb & engine combination.
3) Choke pull off setting incorrect. Adjust to factory specs. Carb can get bumped in shipping or transportation and can accidentally change the setting.
4) Fast idle RPM set too slow. Adjust to recommended RPM.
5)Low fuel delivery. Correct delivery to carb. Usually it is a plugged up filter.
6) Electrical or compression problems on the engine. Do complete tune up & diagnosis to correct the problem.
7) Float level set very low. Check & adjust the float level to factory specs.
8) No voltage/ground to the idle solenoid (if equipped). Check for power & ground. Repair the problem as required.
9) Defective idle solenoid. Replace/repair problem as required.
**RED SEAL CERTIFIED JOURNEYMAN SINCE 1993**
My 1966 GMC Value Van Project
1951 GMC 9430 1-Ton
I'm just going to put an OUT-OF-ORDER sign on my forehead... and call it a day.
Aberdare is offline   Reply With Quote
Old 04-21-2018, 07:35 PM   #15
VOoDoO70
If I start the engine and throttle the pedal to hold the rpms it will stay running. Once I let off the pedal it dies. Aberdare, Im not sure what steps 3 4 8 and 9 actually mean as far as checking them on my setup to see if they are properly set.
Old 04-21-2018, 07:39 PM   #16
rockyrivermark
Get that fuel pressure down first.
Can't stress enough how edelbrock carbs are funny about fuel pressure.
My build page
Old 04-21-2018, 07:40 PM   #17
7 Devils
7 Devils's Avatar
Have you pulled any of the plugs to see if they are getting foulded? A vacuum gauge would be helpful so you could veriy no leaks or timing.
Dan
Old 04-21-2018, 07:48 PM   #18
Aberdare
Aberdare's Avatar
These are not "STEPS" - they are items to be checking... from most common to least probable. This is old school diagnostics... so print yourself off the specifications sheet for your carb, and start checking.
From personal experience I would say that #2 is your most likely culprit.
1951 GMC 9430 1-Ton
Old 04-21-2018, 08:29 PM   #19
VOoDoO70
I went out and bought another fuel pressure regulator as the one I installed previously had no effect on the fuel pressure, Im installing it as we speak. So going down the checklist I starting messing with the choke and discovered if I close the choke and clamp it down the truck will idle! Sounds right too. Once I hit the throttle it will die. Do I need to adust my fast idle screw? The cam and screw are currently not touching unless I manually close the choke by hand. I never have the choke closed but once I did so it actually stayed on. Ive never messed with the fast idle screw how is it supposed to be set?
Old 04-21-2018, 08:42 PM   #20
Aberdare
Aberdare's Avatar
Now... think about this... Choke - What does the choke do? What is its purpose?
... with the choke is closed, the engine idles... what does this tell us? I know what it tells me. -- less air -- same amount of fuel... therefore; idle mixture is incorrect... but WHY is the idle mixture incorrect? Wrong setting? Idle speed? Fast idle? Vac Leak?
Mhmmm... sounds to me like a vacuum leak is your culprit - Item #2.
1951 GMC 9430 1-Ton
Old 04-22-2018, 09:12 AM   #21
I've been away, just got back, haven't read thread through, but saw the title and first thread. I'm sure there have been many helpful suggestions but let's get our terminology straight for now and all future issues. If people want good help and get straight to the issue, I suggest knowing the difference between cranking over, firing, and running.
From what little I have read here I see your truck cranks over, fires, and starts, but the issue in not idling.
*Cranking over means battery and engine will turn engine. No spark and/or no fuel
* Firing means you at least get some spark and some fuel. No start
* Starting means just that. It's running. If it doesn't, look back to other two
* Idling means sit there and run w/o giving gas
Just trying to help people help themselves with giving correct information to start things in the right direction and get straight to the issue.
Old 04-24-2018, 07:47 PM   #22
CC69Rat
CC69Rat's Avatar
Yep -- the electric FP and Edelbrock carb is the issue. Fuel pressure regulator is a must for those carbs. Too much pressure can cause what youre describing with it dumping gas down the bowls too.
If you read up more on that carb, it will also tell you you'll need a carb spacer or the heat will radiate up through the body of the carb itself and cause vapor lock (fuel is boiling in the bowls)
Not only that, Edelbrock recommends their $100+ fuel pump for it. A stock mechanical fuel pump is too much for a 1406 / 1407. I can only imagine what kind of pressure the electric pump is pushing to it.
I see two options for you my friend -- change to a Holley, or a fuel pressure regulator ( a good one) which negates the benefits you'll see from the electric pump.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-24-2018, 08:04 PM   #23
rockyrivermark
Yep. I put a 1/2" spacer. Cheap. $25. Funny thing I have phenolic at my shop, could have made us easily. Works well.
I have a stock mechanical pump but gauge reads 5 psi so good.
Get the pressure down and report back of that helps.
Mark
My build page
Old 04-24-2018, 11:10 PM   #24
VOoDoO70
Ive always been a holley guy, hell I run a holley on my camaro, the truck came with the Edelbrock when I bought it and didnt see a reason to change it at that time since it ran well. I bought another fuel pressure regulator but need to install it, just been tied up at work. I also bought new plugs and wires since its been sitting for awhile. I will update once I get a chance to slap everything on. Thanks for the help
