Old 08-05-2011, 02:40 AM   #1
ky_kid
ky_kid's Avatar
What transfer case do I have?
Can someone tell me how to identify my transfer case?
203, 205, 208... I know the differences between them but how can you tell them apart visually?
84 K10 Custom Deluxe: 350 crate engine w/ 4" lift
ky_kid is offline   Reply With Quote
Old 08-05-2011, 02:49 AM   #2
rcbildr
rcbildr's Avatar
Re: What transfer case do I have?
The cases should have a tag on them. The 203 and 205 have a cast iron case and the 208 is aluminum.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 08-05-2011, 10:29 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
88 208
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-05-2011, 12:18 PM   #4
Jonboy
Slots go on anything!
The easiest way (to me) is the shift pattern, and case construction. Your truck most likely would have a 208 case. The shift pattern from top is 2hi, 4hi, N, 4 low. The shifter is mounted to the cab floor, instead of to the case itself.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-05-2011, 12:57 PM   #5
bmchevy1979
bmchevy1979's Avatar
pic#1 NP203
pic#2 NP205
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 08-05-2011, 01:39 PM   #6
ky_kid
ky_kid's Avatar
Thanks guys... great info
Old 04-30-2018, 12:23 AM   #7
Unions
What transfer case would come stock in my 1972 Chevrolet 1500 sb350
Unions is offline   Reply With Quote
Old 04-30-2018, 11:01 PM   #8
Indyfab
Indyfab's Avatar
Should be a NP205
Indyfab is offline   Reply With Quote
Old 04-30-2018, 11:09 PM   #9
Killer Bee
Killer Bee's Avatar
found this recently while browsing the interwebs..
TRANSFER CASE SPOTTER’S GUIDE
posting pictures of yours will help too, good luck!
Old 04-30-2018, 11:17 PM   #10
Unions
Np 205 is that the one with the chain but more importantly where can I find a how to manual to dropping the tranny and transfer case down safety
Old 05-01-2018, 07:11 AM   #11
sweetk30
sweetk30's Avatar
np205 = part time gear to gear
np203 = full time gear to gear range box and chain for the front output .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
