Tires
What's the biggest tire guys are able to use on stock rally wheels and without chopping the truck bed? I'd like bigger back tires and stock up front . Thanks in advance
![]() Join Date: Oct 2014
Re: Tires
I'm running 275/60's on an 8" rally. That's with a '71 5 lug rear end. The fit is right on the money
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
Re: Tires
That's a great look on the truck, nice truck man! Thanks for the info
Re: Tires
![]() ![]() Join Date: Mar 2016
Re: Tires
BFG 285/70-15 on rear 245/60-15 front for my step side, and my 71 longbed.
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE ![]() Last edited by 3757chevy; 03-14-2018 at 10:35 AM. |
![]() Join Date: Dec 2012
Re: Tires
I’m running the same size as RodnRudy
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#7 | |
Re: Tires
The front tires are 225/70 15. Fronts are mounted on 6 1/2" rallys. Thanks for the compliment on my truck!
Re: Tires
I'm running 8" rallys with BFG 275/60/15 on all for corners.
#9 | |
Re: Tires
awesome truck and stance... how much of a drop if you done mind me asking.. this is the look I want for my 72
1972 Chevy C10 400sbc 4sp Matthew 4:19 And he saith unto them, Follow me, and I will make you fishers of men. |
Re: Tires
I'm not running rally's, but if you find one that would fit a 295 width tire, it should fit without chopping anything up. You'll just need the right backspacing to get it to fit. I'm running 295s on a 10" wide wheel with 5.5" backspacing on a stock 71 width rear.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
Re: Tires
Thanks. The front has a 3 1/2 in drop (2 1/2" drop spindle and 1" drop coil) from Early Classic Enterprises. The back has about a 5" drop on it. Its a leafspring rear and was done by one of the previous owner so its hard to tell for sure. I added the front drop kit after i bought it to convert from drum to disc. My buddy's 72 has the 3 1/2" front 5" rear drop from Early Classics and his is a coil spring rear setup and they sit pretty close to the same height which is why I stated I have a 5" drop on mine.
Re: Tires
I've got 2 1/2" drop spindles and 3" drop springs in the front and 5" drop springs and 2" lowering blocks in the rear. That makes it a 5 1/2, 7" lowering overall. I do have the c notch in the rear frame. Thanks for the compliment!
Re: Tires
I guess I should pay attention before i quote a response intended for someone else. My bad....
Re: Tires
Don't feel bad, I just figured out how to do the quote thing yesterday! LOL
#15 |
Re: Tires
I currently run 275/60/15 cooper tires and they look sharp. Will get a set of BFG soon.
| Bookmarks |
