#26 | |
Re: Rattle Can?
#27 | |
![]() Join Date: Oct 2016
Re: Rattle Can?
72 White Cheyenne, The Ghost |
#28 |
Re: Rattle Can?
Depends on how fast you want to paint. If your fine doing a bedside, waiting a few minutes, and repeating all the way around the truck an 8 gallon should be fine. To your point if you want to paint continuously you need a lot of air, my compressor is 80 gallons so I guess I take that for granted.
#29 |
![]() Join Date: Mar 2018
Re: Rattle Can?
#30 |
![]() Join Date: Dec 1999
Re: Rattle Can?
I bought this compressor at harbor freight to spray some cabinetry in a house I was working on. It runs the harbor freight purple gun fine. I have used the purple gun to spray acrylic enamel and some urethane with no problems and a nice finish. I got it for $149 and they frequently have a coupon.
https://www.harborfreight.com/air-to...sor-61454.html 5.8 CFM @ 40 PSI, 4.7 CFM @ 90 PSI Purple Gun: https://www.harborfreight.com/20-fl-...gun-62300.html Says Average Air Consumption 6 CFM @ 40 PSI which is really close to what the compressor can put out. Like someone said above sometimes you have to let the compressor catch up. |
#31 |
Re: Rattle Can?
Well *#• dammit . This thread has me right back at square zero
![]() Paint gun Rattle can paint gun rattle can paint gun ...
M.A.G.A.
#32 |
![]() Join Date: Oct 2011
I think the rattle can thing works....but it is a last choice within reasonable choices for that particular task.
Rattle cans are great for smaller areas, detailing etc....but when you start to have to cover the square footage of an 18ft truck the scale of advantage vs. effort and results disappears in a hurry I think. I think once you start buying a box of 16, 20, 25 cans of rattle paint.....it starts to become clear that you aren't on the best road for a paint project, lol. Let alone the putz around time shaking cans, grabbing the next one, paint-appearance continuity, etc, etc. At that point, a compressor (even renting one), a spray gun and some basic paint will go faster, farther....for not too much more money I think...and this was well mentioned by Problems and others. My two bits. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 Last edited by Coley; 05-10-2018 at 10:54 AM. |
#33 |
Re: Rattle Can?
Maybe think of it this way:
If you end up with a result thats 2 or 3 times better and it cost you $150-$200 more.....would that work?.....and to build on that.....the result also comes a lot quicker noting that it will probably take you 1/4 (or faster) of the time to paint the truck once you start. I'm pretty sure you'll be out there for hours and hours with rattle cans and a very sore arm and shoulder, lol. So if you pay yourself even $10/hr for your hobby trouble...that too starts to offset the costs of the compressor driven paint job. Now....I've never painted a truck with a compressor etc and I am familiar with the 'rattle can' advantage but I've always wondered about the tipping point in this. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 Last edited by Coley; 05-10-2018 at 10:52 AM. |
#34 |
Re: Rattle Can?
That’s plenty, my gun says 7.1cfm @ 50 PSI. I run my regulator at the compressor at 90psi and then a regulator at the gun pulling it down to 30-40psi depending on what I’m spraying.
#35 |
Re: Rattle Can?
Rattle can 4 life
Spare can in the back pocket I can paint a whole car in an hour on the side of the road with Minty results. 6am no wind. Washingoing by noon.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#36 | |
Re: Rattle Can?
#37 |
Re: Rattle Can?
This is too good. Made me lol for real. My buddy had a 1986 Pontiac Parisienne (Chevy Caprice) that was grey and we flat blacked the whole car with 4 cans from Walmart. $4 paint job. Rattle can 4 life
#38 |
Re: Rattle Can?
remove rust
2k prime bare metal sand the whole area with 180 grit buy a wagner electric sprayer quart of olympic gm white quart of clear now you have an electric sprayer for all projects |
#39 |
Re: Rattle Can?
#40 | |
Re: Rattle Can?
I want to paint with my gun, compressor, mask etc. I have the major components but zero experience. I'm ready to give it a shot though. Major hurdles for me are: - Cost (paint is more expensive, primer is more expensive too) - Availability of paint (in the color/sheen I want) - Time tracking down all the needed stuff (mixing bowls, something to clean the gun, etc etc) - Time figuring out the process of mixing, spraying, adding new paint to continue the job etc etc - Time figuring how to clean the gun, then cleaning it - Time doing proper prep of existing paint to accept primer - Time doing a proper primer job I would spend the same amount of time on the bondo body work that needs to be done either way. I've never done body work so I'm not expecting much in the quality of finish (but it will be miles better than how it currently sits) Farm fresh if you know what I mean. But, rattle canning, you can pretty much scuff with red scotchbrite existing paint then spray right over that. Rattle can I'm looking at using is primer/paint combo. I know rattle canning is a cheap crap way to paint a car/truck. This truck will NEVER get a professional paint job (not while I own it). Just not that important to me. I have about $3500 into it so far and probably another $800 to get it driving and functioning safely. At that point spending $60 and a morning rattle canning sounds pretty good haha. A couple hundred bucks more would be doable, just have to do more research on finding a satin single stage in Sea Glass color in California.
#41 |
Re: Rattle Can?
#42 |
Re: Rattle Can?
#43 |
Re: Rattle Can?
I've done both and still do both.
For quick repair, say fender, rattle can is great. Tape it off and shoot. Obviously prep was done. I use painters touch made by Rust-Oleum sold at home Depot. Drys fast and under $4 a can. Coverage is great too. Painting my whole truck or just the bed. Then buying by the gallon is more cost effective. $40 for a gallon at tractor supply. $10 for hardner. $8 Naptha for thinning. $15.00 harbor freight HVLP gun A gallon of paint really becomes 2 gal So you able to lay down a couple of good coats. Don't forget to wet sand the whole truck first. I spent a week on prep and a couple hours to paint it. Good luck |
#44 | |
Re: Rattle Can?
#45 |
Re: Rattle Can?
If you can get your hands on a gun and compressor it is easy and will have good results. I epoxy primed mine with Eastwood epoxy. I got 2 k high build local for like 100 bucks. I sprayed it all with a HF gun (34$ 2 pack) used the large gun with the largest tip. The 2k high build was rough to the touch but sanded nice. A buddy of mine carried it to his shop and shot the paint (side job hes the painter for a custom rod shop) it does have a few imperfections but not bad for never being in a booth.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS Last edited by Robznob11; 05-10-2018 at 11:00 PM. |
#46 |
Re: Rattle Can?
Now this is what it looked like when I finished my part maybe 400$ and hours of labor. And the second pic is it now with a 2800$ side paint job. It's all in what you want. I could have rolled it in primer and still grabbed eyes!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#47 | |
The pickups normally have a wide strip, like 18" in the middle or the doors. one can do rattle can. The issue with rattle can is keeping the edge wet. The wider the area the harder it will be. The real issue for me is clean up. With a rattle there is none. spray gun take a little more time to clean up. I've done nice paint jobs too, but your looking about $150 for a qt of paint / qt clear coat /qt thinner / pint of harder. When I'm spending that kind of money I go to my friends shop and he paints it. |
#48 | |
Re: Rattle Can?
#49 |
Re: Rattle Can?
#50 | |
Re: Rattle Can?
One aspect you don't have to worry about with the cans is the moisture in the compressor. In the end, if you see any rough areas, color sand it, and polish. |
| Bookmarks |
