Old 05-05-2004, 05:48 PM   #1
Low87
been here longer than Liz
Low87's Avatar
how to fix loose steering?
The steering is pretty loose in the 77, what do I need to check? I'd like to tighten it back up, make it feel solid. It does have power steering.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 05-05-2004, 06:42 PM   #2
Izzy
Trucker.
Izzy's Avatar
Check the play in the balljoints, pitman arm and idler arm.
Izzy is offline   Reply With Quote
Old 05-05-2004, 06:47 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
What's loose? Like 5-8 said track down where the play is coming from. My guess is a front end rebuild kit should be on your "To do" list....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-06-2004, 01:09 AM   #4
C-10volvo
C-10volvo's Avatar
it also could be your steering box. you can pick one up in a junk yard for 20 bucks.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 05-06-2004, 01:18 AM   #5
low 84
low 84's Avatar
check the tie rods and rag joint where the shaft goes into the box also.
but there really isn't going to be something you can "adjust". you most likely have some worn out steering components that need replaced. there is adjustment in the steering box but with other things worn out its not going to help anything
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 05-06-2004, 08:57 AM   #6
Low87
Low87's Avatar
Thanks for the replies guys! Where can I order a front end rebuild kit from? I'll check around as time permits today at work. Trying to price my to-do list and prioritize things, with safety issues coming first.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 05-06-2004, 09:39 AM   #7
Izzy
Trucker.
Izzy's Avatar
http://www.p-s-t.com
I would get their bushing kit and then use Moog tie rods, pitman and idler arm.
Old 05-06-2004, 10:26 AM   #8
Low87
Low87's Avatar
$189 for the kit, not bad!
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
