Lowered Truck Question
I have a ECE 4/6 drop on my truck and want to go a lot lower. I am thinking about using the Air Ride front A-arms in the front and using bridges in the back to get it low. I am looking for detailed descriptions and pix of lowered trucks. I am trying to decide rather to keep the original trailing arms or going with a 4-link set-up. I am also wondering where the best place to mount the bags to get the most movement of the suspension. I want to go really low but still be able to drive my truck. I am considering a good suspension and a small body drop. Any help would be greatly appreciated. Thanx
1972 Blazer body...need to get a thread started for the rest of the story |
I Did Not Know That Airide's A-arms Were Available Yet. I Checked Last Week And They Told Me Another 30 Days.
I haven't bought any parts, that is just my plan right now.
Let's see some pic's. I'm wanting to bag my truck but it's to pricey for me right now. Here is a link to see my truck. I think it's lower than 4/6.
http://www.ctwtrucks.com/2low72/ |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Take a look at slammed 67's web site on his gmc he has a pretty good write up and pic's on his truck..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
How much lower do you want to go? The AirRide arms I've seen look like some quality pieces.... unfortunately, they don't make them for the 63-87 suspension yet. I've heard they're a month out for a couple of months now. When I spoke w/Darren @ AirRide, word is they still haven't started them. Knowing that, a month for fabrication to production is extremely optimistic.
For the front, I used 2.5" spindles w/1 coil cut from the factory 30yr old springs. This combo dropped my truck almost 6". With 215/75/15's up front on 15x6.5" van ralleys, I buzz the top of the inner-fenderwells on some dips (but only if going too fast). For normal roads it doesn't rub. I installed a 73-87 1 1/16 sway bar w/eurathane bushings & trimmed the factory bumpstops 1/2 ". For the rear, if you want to get it low but still use it like a truck, go w/air bags. I used Firestone 224C's (approx 25-2600#) bolted directly to the trailing arms & added 1.5" lowering blocks from Classic Perf Products. This requires relocating the shocks for more travel & installing a c-section (I got mine from CPP). At normal ride height (30psi is my preference), my axle tube rides about an inch into the bottom of the framerail. When I hook up my car hauler, I air it up to about 60-70psi which returns the truck to unloaded ride height & adds an inch for extra travel. The c-sections allow more travel than the bed floor does in my case....the top of the pumpkin occasionally hits the bed floor (again usually only on dips @ too high of a speed). I've used this truck daily for 3+ yrs w/o problems. Any lower & I would have to lose or raise the front inner wheelwells & cut out the bed floor.
Scoti,
Thanx for the info. I am not going to start actually working on my truck for a year, as I am deploying overseas. I want to get an idea and maybe buy some parts while I am gone. I may try and get my brother to do some of the work for me while I am gone. He and my dad own a auto repair shop with alignment equipment. I definitely plan to bag my truck at all 4 corners. I am also considering raising my bed floor until the wheel wells are even with the bed rails. This should give me at least 4 inches more clearance in the rear. The biggest thing I can't figure out is, if I put bridges in the back, will the stock trailing arms work for a really big drop or if I should go with a 4 link to work better. I think the trailing arms my put the rearend at a bad angle once I get so low. I am also thinking about getting ECE's new crossmember and flipping the trailing arm mounts upside down to raise the point at which the trailing arms attach.
#8 | |
