Header question
Has anyone had any luck putting in the engine with longtubes on it? They are speed engineering 1 7/8 on a 5.3. Gotta figure out where to adjust the sliding mounts and hoping I can do it in one shot. But looking at pics ot looks really close. Cab is on if that makes a difference and it is a 65.
Re: Header question
Are you asking if you can install the engine with headers already bolted up?
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
Re: Header question
Yepper
Re: Header question
Gunnin4ya
Take some pics of the headers after install please as I think those are the same ones That i want to try on my 65 5.3 swap |
meowMEOWmeowMEOW
Re: Header question
I think if the front clip was off you probably could insert it from the front with the headers on. With the front end on though, I'd think you'd have a hard time stabbing it in there.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: Header question
Here you go, I had to cut where the dust shield top portion goes off of my 4l80e. I knew I would the ears but was not aware of the top bolt holes.
Re: Header question
I will get some pics for you Mac when it is installed
Re: Header question
Thanks. Especially the driver side as I am using the original clutch linkage and need to determine whether there is enough clearance.
BMW & ASE Master Certified
Re: Header question
Its like 10 bolts.. why not just remove them and install them when it's in the truck.. seems a whole lot simpler and easier than running around the truck fiddling with it...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Re: Header question
With cpp perches and sliding motor mounts it will not go in with speed engineering 1 7/8 longtubes. Good news is the 4l80e fits with the low hump with about 1/2" clearance. Tons of room on the back of the engine and firewall.
Re: Header question
Wow that sucks. What is your plan B?
Re: Header question
Just took them off and installed them after the motor was in. Had to massage the passenger side. It is a pain doing it by yourself.
| Bookmarks |
