Old 08-08-2018, 09:25 PM   #1
MARTINSR
MARTINSR's Avatar
Re: Cab corners
All you have to do is pull apart a lapped weld that looks perfectly clean to see it is RUSTED inside and you will understand. But the thing is, the ENTIRE cab is made of them, so one more isn't a big deal. Just be sure you clean that stuff up good, epoxy primer it, and seal it with a good seam sealer.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 08-08-2018, 10:31 PM   #2
Matt_50
Re: Cab corners
Your making me paranoid lol.
1950 Build
Matt_50 is offline   Reply With Quote
Old 08-09-2018, 02:08 AM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Cab corners
Originally Posted by MARTINSR View Post
....so one more isn't a big deal.
Brian
But one less IS a big deal. At least to me. Doing it “right” to me makes a lot more sense than the “one more won’t hurt” logic.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 08-09-2018, 09:51 AM   #4
MARTINSR
MARTINSR's Avatar
Re: Cab corners
Dan, the ENTIRE cab is made up of lap, pinch welds, the entire thing. And it's made "properly" so if it had one more part welded to it that same exact way at the factory, that would be a bad way?
If the lap weld is done properly, it's not like adding "one more bad thing" it's just like the factory built it! Hell, in 49 they welded on that strip for the windlace with a "lap" style weld, spot welded right over the metal, no butt, just laid it over the metal around the door opening and spot welded it, how dare them! So that 49 cab is somehow "done wrong" over the 48 cab which didn't have that windlace retainer spot welded there?
I just try to keep it real, not all of us can do the perfect job. And if that lap weld is done properly and cleaned and weld through primer is applied and then it's sealed off well, it's damn near as good as a butt weld. The truck get's done and they are on the road with a smile on their face!
Brian
1948 Chevy pickup
Old 08-09-2018, 12:53 PM   #5
67GMCkid
67GMCkid's Avatar
Re: Cab corners
The "right" way would be to replace the entire rear skin on the cab removing and replacing it the way it was done in the beginning.. Any thing else is a subjective repair..
If you lap it, it could rust. bare steel in the Lap
If you butt it, it could rust. you have burnt the metal welding
If you epoxy it, it could crack loose. if not prepped or mixed correctly.
The scenario goes on.
Do it the best way your skill set, budget and tools allow..
Chances are 30 years in the future 90% of the vehicles that are on this board will no longer exist..
67GMCkid is offline   Reply With Quote
