Old 08-16-2018, 06:24 PM   #1
chris_68c10
transmission help
Hey guys need a bit of help trying to find out if my transmission is good or should i just sell and upgrade. I recently bought a 350 small block and 5 speed Borg Warner transmission off my regional manager at my job. doing a bit of research and found out my trans is a t5 world class transmission. it"s an 88 from a camaro or firebird. what I don't know, is if it's a good transmission or should i just sell it. Any help would be appreciated
chris_68c10 is offline   Reply With Quote
Old 08-16-2018, 06:34 PM   #2
demian5
demian5's Avatar
Re: transmission help
Does it all work ok now and run/drive?
Are you running a 500 HP motor and slicks?
Whats your intended driving purpose of the vehicle?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-16-2018, 06:38 PM   #3
chris_68c10
ya it works. i bought the 350 and trans together and just haven't installed either of them. purpose of driving is just to cruise and enjoy the truck and no the motor is not 500hp. my truck has the original straight 6 and auto trans installed still. it runs and drives great still. I bought the 350 and trans to swap out but now i'm just not sure but wanted to know if the trans is a good one or not cause i might sell both of them or just maybe the trans
Old 08-16-2018, 08:13 PM   #4
Bigdav160
Bigdav160's Avatar
The 6 and the T5 would be a cool (nice driving) combo.
T5's don't like a lot of torque so they need to be babied behind a 350
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-17-2018, 08:52 AM   #5
clay68c10
clay68c10's Avatar
If you’re not beating on it regularly, the T5 should hold up ok. There were a ton of them in 3rd gen camaros and fox body mustangs.
The shifter location may be close to the front edge of your seat, depending on how you mount the drivetrain.
You’ll have to figure out the clutch actuation. Stock for the truck was a mechanical linkage. The donor car was hydraulic. Typical hot rodding stuff.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-17-2018, 08:23 PM   #6
Rickysnickers
It would be worth your while to put a shifter in that has stops on it. I had a Fox body and it was always reported that third gear was made of glass. It was also recommended to me to do the same thing. And that was from the guys at JBA.
