Old 04-07-2018, 09:00 PM   #1
derek_1137
5 speed overdrive in a 1969 c20
Ive got a 1969 c20 with the Muncie 4 speed on a 350. I've been looking to put an overdrive transmission in and was looking for some help from people that have done this in the past. I've heard that the t5 put of the S10 fits with no fabrication or drive shaft alterations however I'm curious I to the nv3500 five speeds that came out of the s10s with the v6 will also fit. I have access to one and I don't want to do to much extra work has anybody tried putting one of these in their pickup? And if so what was needed to get it to fit?
Thanks a lot I appreciate the help, Derek
derek_1137 is offline   Reply With Quote
Old 04-07-2018, 11:51 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 5 speed overdrive in a 1969 c20
Here is a thread that covers a lot of that stuff.....
http://67-72chevytrucks.com/vboard/s...d.php?t=438224
LockDoc
Leon
Old 04-08-2018, 10:59 AM   #3
Kennuck
Kennuck's Avatar
The T5 is a weak trans especially the non world class. The NV3500 is a stronger trans, however neither are C20 strength in my opinion. If you use it as a 3/4 ton truck you would be much happier with an NV4500
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 04-08-2018, 09:07 PM   #4
treveiger
treveiger's Avatar
Either a tko 600(if you have money and want more of a performance transmission)or a nv4500 if your going to use it as a truck. A nv4500 will be my choice unless I plan on racing.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 04-09-2018, 08:55 AM   #5
s10mk
I think in your case, a ranger overdrive torque splitter is a viable solution.
Or at least its one that I would consider. http://www.advanceadapters.com/categ...-splitter/236/
2009 GMC Sierra 1500
2006 Buick Lacrosse
1987 Chevrolet V10
1972 Chevrolet c20 350/350
1967 Chevrolet Biscayne ls3 swapped
s10mk is offline   Reply With Quote
Old 04-09-2018, 02:18 PM   #6
weim55
Can't believe I've never heard of this splitter box before. That's a nice unit!
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 08-29-2018, 03:44 PM   #7
Theamazingmrfixit
Looking to swap a NV4500 / Chevy trans in place of my TH350. Any help would be appreciated. What did you use for a clutch package? interested in using a Hydraulic clutch set up.... Help
Theamazingmrfixit is offline   Reply With Quote
Old 08-29-2018, 03:48 PM   #8
Theamazingmrfixit
Sorry, I am new to this stuff ( Forum's) Looking for help sourcing parts for my 1970 C-10 conversion from th350 to a NV4500 .. I have a transmission and bellhousing, But asking for help with the clutch package and linkage. Looking to go Hydraulic and hopefully a robust set up and not plastic if possible.
Old 08-29-2018, 07:45 PM   #9
Red71gmc
I had a 5 speed behind a v6 in a 84 S15. I always considered it just enough trans for the v6. In no way in the same heavy class as the old granny 4 speeds. IMO
Red71gmc is offline   Reply With Quote
Old 08-29-2018, 10:59 PM   #10
LockDoc
LockDoc's Avatar
I didn't use a hydraulic clutch but here is how I did it using all of the stock mechanical clutch parts....
http://67-72chevytrucks.com/vboard/s...d.php?t=673588
I don't know what year NV4500 you have so that might make a difference. The one I used is listed in the thread.
LockDoc
Leon
