Old 09-02-2018, 10:52 AM   #1
Gregski
Gregski's Avatar
How To Remove Trans Oil Pan?
"Do you even know how to drive an automatic?" the famous Hangover quote comes to mind
So I am not a complete idiot but whilst lying under said ride a gorgeous 1969/71 350/350 true short box GMC 2WD I realized one may need to move the transmission crossmember out of the way to get to the rear 2 bolts on the transmission oil pan in order to drop said pan.
Man, I thought... them TV car drama shows never show that, they just go bzzz bzz , ha ha and the next thing you know their trans pan is in their hands.
So my question is, is that how it be on these trucks or do I have a non OEM cross membrane on mine?
I will upload a pic after I have some scrambled eggs here this mornin'.
Gregski is offline   Reply With Quote
Old 09-02-2018, 11:03 AM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: How To Remove Trans Oil Pan?
Yes every one I have worked on I did.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-02-2018, 01:30 PM   #3
OregonNed
OregonNed's Avatar
When I removed mine I was able to use a jointed socket extension to get in on those. My crossmember is stock. However, the previous owner elected
To leave the manual trans crossmember in the truck so we had to unbolt the trans and lift it slightly using a 4x4 on end on the fork of a small forklift. Fortunately we have a lift so the truck was up high to do this.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 09-02-2018, 02:35 PM   #4
Gregski
Gregski's Avatar
thanks
Old 09-02-2018, 02:35 PM   #5
Gregski
Gregski's Avatar
thank you, that helps
Old 09-03-2018, 10:48 AM   #6
Rich69shortfleet
I've never had to touch the crossmember, just got after a couple of the bolts with an end wrench instead of a socket.
Rich69shortfleet is offline   Reply With Quote
Old 09-03-2018, 12:50 PM   #7
custom10nut
custom10nut's Avatar
I use a short socket and an extension with the “Swivel” tip. It clears the crossmember just enough to access the bolts.
custom10nut is offline   Reply With Quote
Old 09-03-2018, 07:59 PM   #8
Gregski
Gregski's Avatar
copy that
