Do I need a high hump for a 4L60E?
Hey folks. I haven’t been on here in a while with a question but finally getting back to my project. Was wondering do I need a high hump trans tunnel to run a 4L80E and a 5.3 or will a low hump work just fine? I was thinking the trans is bulkier on the driveshaft end of the trans. Thanks
1980 Malibu Classic 2 dr coupe 1964 Impala SS 4 speed 1968 GMC (major project) grandpa bought new 1969 Chevrolet C-10 Shortbed Fleetside 2013 Silverado LT Last edited by Bryan H; 09-10-2018 at 09:13 PM. |
Re: Do I need a high hump for a 4L60E?
I'm running a 6.2 with a 4L60E and the low hump works fine. It's tight on the top, just a couple of inches, but it fits OK. No issue with the column shifter hooking up either, I used a Lokar rod kit. Had to bend it a little, but it works excellent.
On a previous build, I had a 5.3 with a 4L60E there as well, no issues with either one. Hope this helps, and good luck!! |
Moderator
![]() Join Date: Jun 2017
Ditto on the no need for the high hump...
Have mine installed now and no worries with clearance... ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2025 Chevy Equinox ![]() ![]()
Thanks y’all.
1980 Malibu Classic 2 dr coupe 1964 Impala SS 4 speed 1968 GMC (major project) grandpa bought new 1969 Chevrolet C-10 Shortbed Fleetside 2013 Silverado LT |
low hump and 4l60e combo work with truck pan oil pan on a slammed truck? im about to fit the engine but heard I might need a f body oil pan.
1965 C10 long box laid out on bags ![]() instgram 65see_x .……………………….. ____ ..………________//__l \_____ ,,,,,,,/__(O)___//___/__(O)_/ |
![]() Join Date: Aug 2004
Anything lower than 4” in the front will need the fbody pan
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
thanks I wasn't sure if I could raise the whole engine and tranny up or not.
Retired USAF
![]() Join Date: Jun 2016
| Bookmarks |
