![]() Join Date: Sep 2017
Couple of AD questions
Ok, I bought both the 48 and the 54 in pieces, so I need some help.
On the underneath side of the dash for the 54, this bracket hangs down. IMG_2058 by Robert Moorman, on FlickrI have no idea what "hangs" there under the dash. It has nothing to do with the cowl vent, I know that. Then regarding the cowl vent, I had some bad news today. I was dissembling it as I'm starting on the 54 and found the ear that is riveted on the dash piece had come off. Actually, the rivet (I think) had rusted in to. IMG_2057 by Robert Moorman, on FlickrIs this a rivet? Would a bolt work, since it would be a PITA to try and buck and hammer a rivet in there. What have others done? Thanks |
![]() Join Date: May 2007
Re: Couple of AD questions
the bracket is for a wiper motor.
the rivet lets the bracket pivot, so whatever you put in there will need sleeved so you can get it tight but still let it pivot.
Sleeving it as Joe said would be the right way, but the "bestest" way would be using a bolt that is the same size and then use a jam nut or a lock nut.
One style "lock nut" which is what I would use there. ![]() Or ![]() Or of course. ![]() Or the "jam nut" Which this photo I found is interesting being apparently I have been doing it wrong all these years! ![]() But using a jam or lock nut you can tighten up the bolt but still leave it loose enough for the hinge to work without the nut falling off one day. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Thanks guys.
The vent cowl swivel arm is interesting. I'll look for a really small bolt that I can lock washer. The wiper motor bracket, that makes sense. |
#5 | |
Brian
Sorry Brian, I did read your post and just misspoke. I'll look for a bolt that I can put 2 nuts on to lock it so it doesn't move.
Thanks. |
#7 | |
Brian
| Bookmarks |
