Old 11-18-2018, 08:03 PM   #1
rcazwillis
Power Master Cylinder
Anyone know if any parts stores have power master cylinders. The one from NAPA was a manual. Their parts list did not distinguish power vs manual. Tried one, manual. Oriellys does not distinguish.
I know online vendors have it, like to buy these type of items local.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 11-19-2018, 10:16 AM   #2
jocko
jocko's Avatar
Re: Power Master Cylinder
They should have both. I like to buy this kind of stuff local also - much easier to return, which seems to be necessary all too often. I believe the only difference between power and manual mc for a given configuration is the depth of the pushrod hole in the piston. If I recall, the power mc has the shallow hole and the manual mc has the deeper one, but it’s been awhile... How did you determine the one you got was a manual rather than power? I’m pretty sure last one i did this I got it at OReilly - for a 71 C20.
Old 11-19-2018, 11:05 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
This Raybestos master cylinder (RMC39075) is listed as being for a 3/4 ton with power brakes. Here are the cross reference numbers for other suppliers. I don't know how current this list is or if part numbers are still good.
Leon
Old 11-19-2018, 10:12 PM   #4
rcazwillis
The deep hole in the plunger. Oreilly said they would order them to see what works. May go with that option.
Zane's 71 Build
Old 11-19-2018, 10:13 PM   #5
rcazwillis
So the 3/4 ton should be the same? I was wondering if there was a difference.
Zane's 71 Build
Old 11-19-2018, 10:27 PM   #6
jocko
jocko's Avatar
3/4 ton and 1/2 ton mc's are not the same. On a 3/4 ton mc in 71 (I assume this is for your 71?), the forward port is for the rear brakes and the rear port is for the front brakes - opposite of the 1/2 ton mc. Yes, the 1/2 ton mc is more intuitive, but that's what ol uncle GM did. You need to specify 1/2 vs. 3/4 ton as well as power or manual when buying to make sure you get the correct one.
Old 11-19-2018, 10:50 PM   #7
rcazwillis
Yes on the 71. I ordered the part from Classic Parts last night along with front hoses. Hope they are long enough.
Thanks for the quick response on the 3/4 vs 1/2. I assumed they were different.
Zane's 71 Build
Old 11-20-2018, 01:05 AM   #8
LockDoc
LockDoc's Avatar
That's why it is always a good idea to state in your first post what you are working with.....
LockDoc
Leon
Old 11-20-2018, 05:08 PM   #9
demian5
demian5's Avatar
This is a great way to look up parts along with rock auto.
http://www.centricparts.com/
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
