Old 12-17-2018, 02:09 PM   #40
dsraven
Re: Bagged woes
another thing to watch for is where to mount the valves. a single valve mounted in the middle of the axle could do the whole rear end but not be specific to each side. less messing around with getting them syncronized so one doesn't fight the other. if you need room for rear dump exhaust pipes or whatever then that may also dictate the valve mounting and air line routing. always try to cover the plastic line with something to stop chaffing unless it is tied down well. some heat shielding may also be required if close enough to exhaust systems.
