Old 03-14-2013, 06:15 PM   #1
Longhorn 70
Longhorn 70's Avatar
Cab mount bushing replacement without lifting cab??
Is there a way to replace cab mount bushings and hardware without removing the cab from the frame? Could it be loosend on all sides and lift and support carefully and evenly enough to squeze new ones in? Should the core support mounts be done at the same time?? I don't have a space to lift the cab off or do "major work" without upsetting the HOA.
3 of them look good but there is one that is trying to split and escape.
Thank you in advance for all suggestions.
Vince
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-14-2013, 07:22 PM   #2
JointTech
JointTech's Avatar
Re: Cab mount bushing replacement without lifting cab??
subscribed because in my peanut head i was thinking they would just "come out" when i wanted to swap them.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 03-14-2013, 07:24 PM   #3
bigbadchev72
People know me
bigbadchev72's Avatar
Yes, just get a floor jack and a piece of 4x4 and lift the cab with the jack and put the new ones in, I believe the core supports come in the kit.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 03-14-2013, 07:29 PM   #4
Lattimer
Lattimer's Avatar
Same thing, I did mine with a floor jack and a block of wood. You can get a good half inch of space, which is plenty to change the mount.
I only did the 2 front cab mounts under the floorboards, the rest still look pretty good.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-15-2013, 11:50 AM   #5
Longhorn 70
Ordering poly mounts today.... Install in 6 months when I get permission from the boss Are there better or worse mounts? I will probably go to LMC or GMC Paul.
Old 03-15-2013, 01:00 PM   #6
twangismythang
twangismythang's Avatar
I got my prothane mount kit off of ebay for 60 somthin bucks shipped. That was the cheapest route, I only wish I would have got new bolts since I'm doin a cab swap. Anyway Im sure the old bolts will be fine, the vender was streetrays inc. out of Tx.
Doin my cab and motor swap as we speak........
Victory will only be achieved through superior firepower and trusting in the Lord.
SOLD 68 C-10. http://67-72chevytrucks.com/vboard/s...d.php?t=560975
SOLD 2000 Silverado...http://67-72chevytrucks.com/vboard/s...=1#post6492671
87 V-10 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=643898
twangismythang is offline   Reply With Quote
Old 03-15-2013, 01:26 PM   #7
72tutone
Yep x2, block of wood, floor jack. I replaced all four and the core support. i ordered rubber ones to replace. They were not that difficult. A lot of mine crumbled out.
Note the bolts in the front two are welded to the floorboard in the cab. Air chisel works wonders
72tutone is offline   Reply With Quote
Old 03-15-2013, 01:53 PM   #8
Lattimer
Lattimer's Avatar
I don't think they should be welded. Mine were just in there with a washer, and I'm pretty sure they were original.....everything else seems to be and those bolts were just as old.
Shawn
Old 03-15-2013, 02:24 PM   #9
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
I replaced mine with poly mounts,improved the handling(less body roll)but you feel every vibration and pebble you hit.
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 03-15-2013, 08:01 PM   #10
Longhorn 70
Thanks all for the advice and suggestions. I only found the rubber ones. Couldn't find poly. 1970 Bowtie, thanks for the input, after reading your post, and wanting a smoother ride, I am glad I didn't find the poly.......
OK updates when they are in .
Vince
Old 03-15-2013, 08:57 PM   #11
72tutone
Hmm strange. I'm the 2nd owner and mine had a tac weld on the bolt head to the cab floor.
Old 03-16-2013, 11:16 AM   #12
formikaus
formikaus's Avatar
Neither one of my trucks had them welded in.
Longhorn 70. A little FYI..... The nuts on the FRONT mounts are locking nuts which means the inside of the nuts where the threads are, are kinda triangle shaped. When tightened onto the bolt they lock on. TAKE YOUR TIME!!! and do not be suprised if you snap one of the bolts. I snapped both fronts on mine when i changed them, but they were pretty rusty.
formikaus is offline   Reply With Quote
Old 03-16-2013, 12:02 PM   #13
Olive1970
Olive1970's Avatar
I wouldn't go with poly mounts anyways. Got my kit from GMCPauls and the parts were good quality and fit, might have to reuse your top shims for the front cab mounts. Did the method as described above and maybe took an hour at the most.
Gary
Slowly looking for my next 67-72 truck
Olive1970 is offline   Reply With Quote
Old 03-16-2013, 01:11 PM   #14
DesertCat
DesertCat's Avatar
My son just did all of mine using a jack and 2x4's as others have said. Bought a poly set off the parts forum here and no, they don't come with bolts but they are easily found at your hardware store. Took him longer to go get the nuts and bolts than to do the job (about 30 minutes).
Rubber or poly? I would have been fine with either.
I have talked and read from those who have gone both ways and the consensus I took away is that there is no discernable difference. Lifetime of poly is supposed to be longer but I doubt I will be driving this thing in 20-30 years anyway.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 12-29-2018, 11:11 AM   #15
EdwardSams
Resurrecting an old thread -
I’m hoping to tackle some panel alignment issues and figured I’d start with the bushings. They don’t look terrible, but would appreciate some perspective from you all. Will swapping out for new make for a better or easier time aligning the doors fenders and hood?
1970 C10
Thanks -
EdwardSams is offline   Reply With Quote
Old 12-29-2018, 11:18 AM   #16
notsolo
notsolo's Avatar
Yep, Best to replace all the body bushings, before you try any alignment. Makes it easier. In the long run.
notsolo is offline   Reply With Quote
Old 12-29-2018, 11:30 AM   #17
Grumpy old man
Grumpy old man's Avatar
Don't forget the core support bushings as well .
Old 12-29-2018, 12:12 PM   #18
EdwardSams
Thanks for the advice!
