Re: 70 Chevy body switch
You could use a second generation (2000–2006) Tahoe for a swb. There are a few people on here that have done it. Plus side is Tahoes can be had cheap, LS motor, abs if you want it, etc...
For your asked swap you need to make sure the wheel base is the same for what you want and you will have to come up with some custom body mounting solution. Also, the tract with will be something else to consider. |
| Bookmarks |
