Old 01-21-2019, 11:13 PM   #176
Advanced Design
Advanced Design's Avatar
Re: Walter DeWayne...Walt for short
Looking good Carter. You are moving right along!
Advanced Design is offline   Reply With Quote
Old 01-22-2019, 11:56 AM   #177
slowcpe
slowcpe's Avatar
Oh man, that looks killer!
I'm still waiting on my wheels so I can have that moment seeing it aired out on the ground.
Edit: You need more pics since its a new page.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 01-22-2019, 12:00 PM   #178
nlped
nlped's Avatar
I ordered a set of Slosh Tubz this morning from Mike. I’m going to get home tonight, pull the body back off, remove the inner fenders and reassemble. Then I can see how Walt will sit all the way down...if the tires clear the fender inner structure.
I’ll snap a few pics of that
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-22-2019, 03:26 PM   #179
knomadd
knomadd's Avatar
Does Mike make an inner fender for the 67-72 that works with the stock hood hinges? I thought his current stuff all required the fenders to be cut and the hinges to be relocated. Looks good, by the way!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-22-2019, 09:07 PM   #180
nlped
nlped's Avatar
I’m going to try “something”... if that doesn’t work, I’ll order hinges.
Carter
Old 01-22-2019, 09:13 PM   #181
nlped
nlped's Avatar
Took the Body back off the frame tonight. Got 17 of the 22 inner fender bolts out but had to soak the other 5...after I smooshed my thumb.
HillBilly dictionary... Smooshed= Smashed+Squished.
I also just sat the Sniper on the intake for the OOOH picture.
Carter
Old 01-22-2019, 11:01 PM   #182
nlped
nlped's Avatar
And... I heard from Nate and he’s expecting to have my new stands finished and heading my way by Monday. That’ll be a huge relief...if I got the height right.
Carter
Old 01-23-2019, 08:45 PM   #183
nlped
nlped's Avatar
So, I’ll be ordering the PB hood hinges
Guess I’ll have a pretty set of black billet hood hinges for sale.
Carter
Old 01-23-2019, 11:29 PM   #184
Advanced Design
Too bad about the hinges though it is good Nate got back with you finally.
Old 01-24-2019, 09:09 PM   #185
nlped
nlped's Avatar
Yeah Doug,
I hate the pretty hinges aren’t going to fly, but you’re right about the correspondence from Nate... just means he’ll get some more of my money.
Carter
Old 01-24-2019, 09:18 PM   #186
nlped
nlped's Avatar
Just for the sake of some pictures. Here is (1st pic) about how it’ll sit at normal ride height, (2nd pic) how the Tire is in the inner fender when trying to air out, (3rd pic) how far apart the frame & body ‘separates’ when the suspension is aired all the way down...
Carter
Old 01-24-2019, 09:20 PM   #187
nlped
nlped's Avatar
And, just for kicks and giggles... here’s how much clearance I have in the front at 80 psi... That’s 5-1/2” above the tire, 8-1/2+ of total lift with a big block.... Not bad
Carter
Old 01-27-2019, 08:44 PM   #188
6t9camaro
6t9camaro's Avatar
Originally Posted by nlped View Post
I also finalized my EFI decision today and ordered the Holley Sniper 550-511 system.
Oh I like your EFI decision!
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
6t9camaro is offline   Reply With Quote
Old 01-30-2019, 05:32 PM   #189
nlped
nlped's Avatar
Thanks man!
Carter
Old 01-30-2019, 08:07 PM   #190
nlped
nlped's Avatar
I got home to find these...
Carter
Old 01-30-2019, 11:16 PM   #191
TA_C10
TA_C10's Avatar
Nice!! Brown truck rocks...
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 02-07-2019, 12:21 PM   #192
nlped
nlped's Avatar
No! They came in a GIANT box and had to come truck freight to a business address. But they sure are purty.
Carter
Old 02-07-2019, 12:31 PM   #193
nlped
nlped's Avatar
I also got a package from Porterbuilt and the new 1” higher mounts seem to have remedied the exhaust maladies. I still need to put the body back on to check fitment, but I know I’ll have to cut the floorpan for a high hump. I have that in my stash of parts so I get that fitted this weekend. The driver side BBC Chevelle header fits like a champ, but the passenger side will require some “redirection” of #2 & 4 to clear the rearmost lower control arm mount.
Carter
Old 02-10-2019, 09:05 PM   #194
nlped
nlped's Avatar
I’ve spent this weekend getting the body stripped of the original equipment items that won’t be reused. i.e. gas tank, wiring harness, etc. I did find rust that I didn’t know was there, but I’m not surprised.
Carter
Old 02-11-2019, 12:19 AM   #195
Advanced Design
Up here in the rust belt, that is cherry.
Old 02-11-2019, 09:16 PM   #196
nlped
nlped's Avatar
Hahahaha. I suppose that’s true. I wasn’t to hurt to have only found that. The cab supports and everything underneath appear solid. I’ll know more when I remove the fenders and blast the bottom, firewall and interior...that tends to expose the bad stuff. I’ve got a friend that does the dustless blasting and he said he’d do it for some work in exchange. I’ve got to finish getting the interior and firewall stripped...& remove the doors, fenders & glass
Carter
Old 08-19-2019, 07:36 PM   #197
nlped
nlped's Avatar
About to get back on WD. Stay tuned
Carter
Old 10-03-2019, 09:35 PM   #198
nlped
nlped's Avatar
I have tentatively sold my 87 today. Once Martha is back running & driving, I’m going to get Walter back up front. I think I’m going to sell the PB chassis though and just do a clean static drop chassis.
Carter
Old 10-04-2019, 11:39 AM   #199
SCOTI
SCOTI's Avatar
I've been following all of your builds (here & there). Hoping things go well on your exhaust expedition. I have an early PBDM (the rare, vintage, C4DM variant) that was built for an intended BBC. I'm fully expecting to have to re-work the MM towers based on what you've posted.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-05-2019, 02:55 PM   #200
nlped
nlped's Avatar
Yeah, the MM’s vs header routing are still a bit of an issue, but I have a few welders and a plasma cutter I’ll get it to work unless I actually do decide to sell off the PorterBuilt chassis and just go static. Then I think all would be fine.
But before I get back on Walter, I’m going to concentrate on Martha for awhile. I’m really hoping to have the first iteration of the Falcon completed by the end of the month #fingerscrossed#
Carter
