Old 02-15-2019, 04:58 PM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
front brake grabbing (locking)
got a 67 chevy c10 which has 4 wheel drum brakes. other day when pulling out of drive the brakes sounded like they where holding, figured out it was the front left brake making the noise. jacked the truck up, and it will spin for as long as i go backwards, but will only spin two or three rounds before it locks up if i spin it forward. took wheel and drum off and everything looks good, drum, shoes, hardware everything looks good. dont see no leaks nowhere and the fluid is still full in the master. went ahead and bleed the left side while i was there looking at it but didnt make no difference. have replaced master cylinder, wheel cylinders,brake shoes,and drums, and new hardware kit in the last 4 months.
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
Old 02-15-2019, 05:11 PM   #2
HO455
HO455's Avatar
Re: front brake grabbing (locking)
Is it possible that the left side hardware is on the right side. I recovered a car that was stolen and the thieves had swapped the brake parts around and caused a similar issue. The other things that pops to mind is how old are the hoses?
RIP Bob Parks.
Old 02-15-2019, 05:31 PM   #3
Wrenchbender Ret
Grind a bevel on the edge of the linings. Sometimes the edge digs in to the shoe & causes this. It could be the hose swollen up inside like HO suggested.
They don't give much attention to drum brakes any more. They used to cam grind the linings & bevel the edges & rivet them on. Now they are bonded on & that's it.
George
Wrenchbender Ret is offline   Reply With Quote
Old 02-19-2019, 02:28 PM   #4
wlf89
wlf89's Avatar
ground a bevel on the shoes with no difference. its just in a certain spot that it locks up, maybe the shoes or drum is that much out of round? it gets tight when spinning backwards in one spot but doesnt lock up.
69 lwb fleetside
67 swb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
Old 02-19-2019, 06:26 PM   #5
demian5
demian5's Avatar
Is the hub loose? Do the bearings need to be adjusted?
Are the back brakes 100%? No leaking fluid?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-19-2019, 07:16 PM   #6
jamyers
jamyers's Avatar
We had a similar situation, the passenger front drum brake would "self-adjust" itself too tight, to where it was pulling the steering wheel to the right when you applied the brakes, and was always barely dragging so that the drum was always warm when the others would be cold.
You could turn it either direction, but backwards was easier (because drum brakes self-engage with going forward and they contact the drums) - and it only drug at 2 points in a revolution.
The culprit was an out-or-round drum, that let the self-adjusting mechanism go too tight whenever the drum was at the "wide" part, then that wheel would drag.
I don't know about parts places around you, but here O'Reilly Auto parts can turn drums for something like $10, assuming you'll have enough meat left on them to stay in spec.
Otherwise, new drums are $25 each at Summit.
My Chevy Truck Project Build Thread
'62 Ranchero - 200 I6, 3-on-the-tree, power nothing.
'71 LeSabre - 455 Stage 1, power everything.
jamyers is offline   Reply With Quote
Old 02-19-2019, 07:17 PM   #7
tdangle
tdangle's Avatar
Another easy thing to overlook is that the short (primary) shoe lining goes toward the front of the vehicle.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-19-2019, 07:47 PM   #8
jamyers
jamyers's Avatar
I re-read your OP, if you've got new drums they *should* be nice and round, unless you've gotten them really hot and then kept holding the brake pedal (like you'd do driving in Dallas - going 75 one minute then braking hard and sitting still for 5 minutes)
If something is only touching at certain points as the drum rotates, then either the hub/drum is moving, or the drum isn't round.
Make sure the bearings are adjusted properly (just a *tiny* bit of slack), then if you have a dial indicator you can mount the drums facing outwards and check the inside surface for out-of-round.
Old 02-24-2019, 09:22 AM   #9
wlf89
wlf89's Avatar
checked the "new" brake drum with less than 50miles on it and it was out of round. took it to the auto parts store to have it turned. he said it was good bit out of round. put it back on last night and its all good now. just goes to show the word new dont mean nothing these days.
69 lwb fleetside
67 swb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
Old 02-25-2019, 01:44 PM   #10
jamyers
jamyers's Avatar
I hear ya! At least you got it straightened out, though
Old 02-25-2019, 05:35 PM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
In my experience a new front drum should be mounted to the hub and checked for out of round before it leaves the parts store. Just a little bit of tolerance buildup can cause an "out of round" condition. I'd recommend that you mark the drum and hub so that whenever you remove the drum from the hub, that it goes back on in the same orientation.
~Steven
Simi Valley, CA
Old 02-25-2019, 06:15 PM   #12
Boog
laying low
Boog's Avatar
The first couple of times I was told I better have new drums turned before install I thought thats just crazy. New parts dont need turned. Two mechanics told me I’d be pulling them off right away. They were right. It is nuts. New parts made to spec should not need finishing before install. Period. It was explained to me after manufacturing they are just dumped in a metal bin and cooled that way so they aren’t stacked neatly and tend to warp some. Sounds bout right.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-26-2019, 10:20 AM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
At the brake drum plant, sometimes too, I guess.
~Steven
Simi Valley, CA
