01-11-2019, 01:26 AM | #76 |
Re: GM connect and cruise engine package
Guess no one uses mufflers? Stainless or?
OLDIRONRACING |
01-11-2019, 11:18 AM | #77 |
On my LS connect and cruise in the 50 I used 2 1/2" pipe with and x pipe and Stainless Works turbo chambered and it dumps in front of rear tires. Mello when cruising with no drone and gets louder more you step on it. very happy with my set up.
1950 3100 5 window |
01-27-2019, 02:02 PM | #78 |
Has anyone used a electric push button e brake?
OLDIRONRACING |
02-04-2019, 09:14 AM | #79 |
Worked on the exhaust this weekend.
OLDIRONRACING |
02-04-2019, 09:15 AM | #80 |
Exhaust
OLDIRONRACING |
02-05-2019, 03:54 PM | #81 |
Fancy exhaust work, nice!
02-12-2019, 11:54 PM | #82 |
Thanks. Hope to make hangers this weekend
OLDIRONRACING |
02-13-2019, 08:33 PM | #83 |
Is there enough room that the trailing arms won’t come up and hit the mufflers? I was considering tipping my mufflers on their sides to get beside the driveshaft and avoid the trailing arms.
02-14-2019, 09:48 AM | #84 |
With the rear suspension bottomed out there is a 1.5 inc of clearance. Bottomed out means rear end touching the frame.
OLDIRONRACING |
02-14-2019, 09:50 AM | #85 |
Has anyone run in to problems with running the exhaust under the trans crossmember with a 4-6 drop?
OLDIRONRACING |
02-16-2019, 11:20 AM | #86 |
A guy with a truck
Yes, you will drag it, or worst case, it looks ugly hanging down under the cab. Try an Early Classic, CPP, or similar type and route over it, or weld in humps using steel pipe
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-16-2019, 12:08 PM | #87 |
I bought a straight across crossmember before realizing it would be a problem with exhaust routing. I modified it with the half pipes that are raised up with some flat pieces. I have the same kind of pipe pass throughs at the trailing arm crossmember as you.
