Old 02-23-2019, 01:39 AM   #26
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: What lift
Originally Posted by 72 k15 View Post
This is getting hard to decide between the 4” and 2.5” I am used to driving trucks that are high I just don’t want it super high what would you guys get if you were in my situation trying to daily the truck?
My K20 was my DD for more than 40 years until I retired. After 20 years, in 1997, the front springs were sagging enough to bottom out often (about 1" from the bumpstops) and I replaced them with 2.5" Softrides which are still on the truck. Personally, I would not want 4" springs on my DD. As it is, my wife struggles to get in & out of the truck, and if it was any taller I'd have to put running boards on it, which I would never do.
Everyone has their own opinion and that is mine.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-23-2019, 01:11 PM   #27
72 k15
72 k15's Avatar
Re: What lift
I think I’m going to go for the 2.5” as everyone is saying that is the best one for daily drivers. Thanks everyone.
72 k15 is offline   Reply With Quote
Old 02-25-2019, 10:14 PM   #28
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: What lift
I went 2-1/2" Skyjacker lift with zero rate spring in back. Here are a couple threads.
http://67-72chevytrucks.com/vboard/s...d.php?t=599446
Also, a thread to the first look after install. http://67-72chevytrucks.com/vboard/s...d.php?t=620627
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-25-2019, 10:43 PM   #29
72 k15
72 k15's Avatar
Re: What lift
Yeah I was looking at your amazing truck when I made my decision for the 2 1/2" lift, What do you mean by zero rate springs? Still haven't ordered the lift will be in a week though.
Old 02-25-2019, 10:51 PM   #30
derotoreut
derotoreut's Avatar
Re: What lift
It's basically a small block, but actually considered a spring. Here is the link to Off Road Design's zero rate: http://offroaddesign.com/catalog/Zero%20Rates.htm
~ Dan
Old 02-25-2019, 10:54 PM   #31
derotoreut
derotoreut's Avatar
Re: What lift
I added the zero rate spring after my skyjacker spring install. I saw that the back of the truck was just a little bit lower. The 1" zero rate spring brought up the back end just enough and leveled it out.
~ Dan
Old 02-26-2019, 11:09 AM   #32
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: What lift
In my case, many years ago I added an AAL to my K20's factory rear spring pack. Then a few years back I added a heavy-duty Hellwig overload leaf spring kit. The truck now sits virtually level with the 2.5" Skyjackers up front.
I'm not recommending this combination, just posting it for comparison purposes. With all that rear spring capacity, the truck has a pretty firm ride. But it handles heavy loads pretty well, which was my goal.
- Mike -
RIP El Jay
Old 02-26-2019, 12:33 PM   #33
sweetk30
sweetk30's Avatar
Re: What lift
hay DEROTOREUT nice to see a local guy .
i am south of you in horseheads just east of corning .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-26-2019, 01:02 PM   #34
72 k15
72 k15's Avatar
Re: What lift
Huh, I will most likely need to add that, you only had a short bed and still was not level wonder what a long bed would do.
Old 02-26-2019, 09:01 PM   #35
derotoreut
derotoreut's Avatar
Re: What lift
I know Horseheads. I used to live in Painted Post and Big Flats. Cool names huh? Nice area. Soaring Museum right? lol
~ Dan
Old 02-26-2019, 09:32 PM   #36
sweetk30
sweetk30's Avatar
Re: What lift
the air port is my back fence
Old 03-05-2019, 02:42 PM   #37
First c10
First c10's Avatar
Re: What lift
4" Tuff Country soft rides up front, ORD Shackle Lift in the rear. 33-12.50 R 15 Dick Cepek Mud Country tires and 15x10 Mickey Thompson/Alcoa Rims
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-14-2019, 04:24 AM   #38
sunnstone
Re: What lift
Awesome truck you got there. I've been planning to modify mine to make it more off-road capable truck but I lack the reference to do so. I already have a set of rockstar wheels I got last December to start with.
sunnstone is offline   Reply With Quote
Old 03-14-2019, 01:17 PM   #39
coopdog
coopdog's Avatar
Re: What lift
4inch with 35s
Took a few leafs out of back
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 03-16-2019, 04:19 PM   #40
Thebrownturd
Re: What lift
2" Tuff country on my 70 netted about 4" of total height gain from where it was before I started. It was little taller than I was hoping, but the ride is much smoother, i have noticed a lot more body roll for sure around corners too. the i put 3" springs on the back but it was way to low so i had to put the factory 1.5" blocks back in. This still did not level out the frame so, I will be putting some 2-2 1/4" block in soon.
Thebrownturd is offline   Reply With Quote
Old 03-18-2019, 09:56 PM   #41
72 k15
72 k15's Avatar
Re: What lift
Little bit of a closure for the thread, I bought a 4" skyjacker soft ride for my from a member on the board. Will post pictures if I ever finish my truck
Old 03-23-2019, 10:38 AM   #42
Razorbacker
Razorbacker's Avatar
Re: What lift
72 K15 - I'm assuming you had factory suspension... if so, what are your intentions with your stock suspension? I'm looking for stock springs to put my K 10 back to original.
Thx
Tony
1972 Chevy K10 SWB Custom Deluxe 350|350|NP205
2018 GMC Sierra Z/71 Crew
2008 GMC Yukon
2007 Chevy 1500 LT
1967 Pontiac Firebird 400
Razorbacker is offline   Reply With Quote
Old 03-23-2019, 11:42 AM   #43
72 k15
72 k15's Avatar
Re: What lift
Yup stock springs, looked to sag a little bit and I’m guessing shiping be would be stupid expensive but if interested send me a pm.
Old 04-14-2019, 06:02 PM   #44
tim71
tim71's Avatar
Re: What lift
My 71K1500 has Tuff Country 2" spring lift. Tires are 32x15 Cooper Discoverer. To me, the truck sits more like it has a 4" lift, to high for my taste. I have a complete set of leaf springs from a 67-72(not sure which year) K20. Any guesses on how my truck would sit with these K20 springs on it? I think the K20 springs are compatable, as replacement springs use the same numbers for K10 and K20. Would the old K20 rear springs be to harsh riding on a short bed? I could save much $ by using the used K20 spring.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 04-15-2019, 11:02 AM   #45
First c10
First c10's Avatar
Re: What lift
My truck has K20 rear springs I have 5 leafs and an overload. I removed my overload spring. How many do your stock K10 springs have how many on the K20's ?
I cant tell you how they ride yet as I haven't got mine on the road yet. close very close!!!
GO GO!!!
Old 04-15-2019, 04:58 PM   #46
tim71
tim71's Avatar
Re: What lift
Both the 2" Tuff Country springs and the original equipment K20 springs have a total of 6 leaves. Both springs lower leaf is much shorter, this must be what your referring to as an overload spring. I didn't measure, but the K20 total spring pack looks a little thicker or taller than the Tuff Country.
Old 04-15-2019, 05:39 PM   #47
First c10
First c10's Avatar
Re: What lift
Sorry yes the short almost flat leaf is the overload leaf.
I am not sure but I think most stock k10’s have 3-4 springs including the overload
My sons c10 had 4 total leafs and when we lowered it we replaced them with a 2 leaf pack.
GO GO!!!
