Re: Depinned engine harness --- now ... ??
Do you have a NSS on your steering column or shifter somewhere? If so you can just use that, or you can use the one bolted to the transmission, but you'll need a relay to use it. The benefit to the trans mounted one is it's more precise and always works in park and neutral where as a column mounted one can be somewhat vague due to the slop in the linkage.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#2 | |
Just trying to work out which wire provides ground out of that. Also ..... with the relay ...... 30 - 12v power from battery with (inline fuse/fuseable link ) ? 86 - wire from key ignition. 87 - goes to purple starter wire in harness to give 12v on crank. 85 - ground from NSS .. not sure which wire Best way to protect that circuit (fuseable link) and what amperage relay etc ? Think the purple wire is a 12awg which I think is max 41A. https://www.amazon.com/Pico-8124PT-G...3463780&sr=1-9 https://www.amazon.com/ARTGEAR-Harne...omotive&sr=1-5
FAKKY 57 PANEL BUILD |
I use fuses. The battery power to the relay on terminal 30 gets a 40a fuse, the purple wire coming from the ignition switch gets a 10a fuse, then that wire goes to pin 12, a pink wire on the NSS plug. Pin 1, a green wire coming out of the NSS plug then goes to terminal 86 on the relay. Terminal 85 will go to ground, and 87 will go to the starter solenoid. I also generally use 40a relays.
#4 | |
Ok a little more confused on that setup - do you have a pic on the web thats similar ? Sorry obviously a little noob on most things ..... but wiring especially at times. I think Ive seen some multi relay - fuse block setups on youtube but thnk generally they have 1 fuse on the power side only for each relay. https://www.youtube.com/watch?v=BvFHA1xY10w Anyway - back to the pinouts ....... Is there somewhere that explains that --- Im guessing you know how to read a full wiring schematic properly ...... so you knew hoe to do that ? Just I havent read it anwhere ..... and my chances of getting a schematic right are about as good as kansas winning the NCAA right now. And If I get it wrong - assuming truck wont start ![]() -- I found an old thread of yours ..... http://67-72chevytrucks.com/vboard/s...d.php?t=615830 but havent seen many people talking about this in other threads - do most people not wire the NSS ?
FAKKY 57 PANEL BUILD Last edited by FAKKY; 03-24-2019 at 08:58 PM. |
What part do you not understand? That drawing g I made in the thread you linked shows it pretty good.
#6 | |
Here are the parts not understanding. 1) I didnt find a single thread explaining that wiring until I searched on some keywords you provided on pinout of the OEM NSS. So Im guessing most people dont do it this way - they just use a column/floor shift with a 2 wire setup that prevents the starter from cranking ? 2) How did you work out that was the way to wire it ? Eg Having the ignition switch going to Pin12 of the range sensor and that that would work ? Just experience and reading schematics and understanding circuitry better ? eg I was searching on Pin #34 as that was what was registered at LT1swap. "Transmission Range Switch Signal P (A/T) PCM can be programmed to accept a SINGLE WIRE park/neutral signal on this PIN, if no trans mounted range sensor is present" <== but guessing this is if your using an aftermarket shifter with NSS ? So - just not sure how you worked that out - except for being just clever ![]() 3) Not clear on how you fuse every wire on each pin of the relay. Physically how is that done. Thx nova/e015475all ....... / none of this would get done without learning from you lot.
#7 | |
