Old 04-01-2019, 09:53 PM   #1
hb32
hb32's Avatar
Manual to automatic transmission swap
Don’t want to but the towing capacity with my NV3500 is less then the weight of my trailer so need to swap for a 4L60E. Besides the transmission, driveshaft alteration, module or computer for the transmission, what else do I need to consider. Truck is a 97 GMC regular cab short box with a 305 which I am happy with. Looked at an LS swap but don’t want the hassle that comes with it. Haven’t found much in the search on here either.
Life is too short to drive a boring vehicle.
hb32 is offline   Reply With Quote
Old 04-02-2019, 04:11 PM   #2
Re: Manual to automatic transmission swap
4L60E is not much better than the NV3500. I have found the biggest limitation was the clutch disc/pressure plate. I have seen way too many 4L60Es die from towing. What are you towing and how often. If it is a lot of towing I would go to a T400 or a 4l80
Old 04-02-2019, 05:05 PM   #3
hb32
hb32's Avatar
Trailer weighs in @ 4300 lbs dry so figure 5k
Not a lot of towing and not long distance or major inclines.
What clutch would you recommend?
Old 04-02-2019, 06:48 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Suggest you look at dual friction plate clutch systems will provide twice the clamping area giving you much more torque capability....$ around $900
IMO...stay away fro 4L60....if you must go auto, go with 4L80e but have it built for towing....and absolutely replace the input shell gear with an upgraded one....$ around $3500 plus everything else you need.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 04-10-2019, 08:45 PM   #5
Tom
driving is in my blood
Tom's Avatar
Why not nv4500?
Old 04-11-2019, 12:22 AM   #6
hb32
hb32's Avatar
Originally Posted by Tom View Post
Why not nv4500?
Thinking of that as well. I have ordered a HD clutch and will see what that does for me.
