Old 03-31-2019, 03:06 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Another wiper motor question
I just bought a new wiper motor for the 67 GMC 3500 that supposedly has the pump in it. Here is what they sold me:
Here is the one that is already in the truck:
Notice that the one in my truck has the three bladed connectors, and two more bladed connectors apart from those. The new one has the three bladed connectors, but not the extra two separate ones. Did I buy the wrong one, or is this some modern upgrade? This new one looks NOTHING like the old one.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 03-31-2019, 04:09 PM   #2
RodnRudy
RodnRudy's Avatar
Re: Another wiper motor question
You only bought the wiper motor. You'll have to take your washer pump off the original motor and put it on the replacement motor. Take your original out of the truck and you'll see what I mean.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 03-31-2019, 05:03 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
If you take the plastic cover and washer pump off of your old one they will look the same.
LockDoc
Leon
Old 03-31-2019, 09:01 PM   #4
HIGHWAY BY THE SEA
I told them I needed the washer pump when I ordered this at the store, so I assumed this was a model equipped with one. Duh!
Old 04-17-2019, 11:03 PM   #5
HIGHWAY BY THE SEA
OK, I bought the ridiculously-expensive washer pump and installed it onto the new wiper motor. Now I cannot get the wiper motor arm crank off the old motor. I have soaked it in PB Blaster all day, but it will not budge. Does this require some special tool or trick?
Old 04-18-2019, 11:41 AM   #6
LockDoc
LockDoc's Avatar
It should just pull off if you have the nut off. Try laying the edge of the arm on something solid like an anvil or the back of bench vise and rap on the edge that is up with a small hammer to break it loose. Mark the front of it with a felt tip pen so you know which side is out and make sure you get it on the new motor exactly the same as the old motor.....
LockDoc
Leon
Old 04-18-2019, 07:10 PM   #7
HIGHWAY BY THE SEA
LockDoc
I will try that. That thing acts like it is WELDED on there.
Old 04-20-2019, 07:14 AM   #8
sKnNyPpY
sKnNyPpY's Avatar
Did you remove the three bolts from the motor under the dash? Just did this myself yesterday. After removing them I gave the motor spindle a tap with a hammer and it came loose. I had to reuse two bushings off the old motor too.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 04-25-2019, 08:57 AM   #9
HIGHWAY BY THE SEA
Thanks for the replies from all. The hammer-tap idea worked, after I left it soaked in PB Blaster for a week. Now I must figure out why the newly-installed wiper motor and pump does not work...? Ground probably.
Old 04-25-2019, 09:33 PM   #10
LockDoc
LockDoc's Avatar
Can you get a picture of the wiper motor and the wiring under the dash? You don't have the wiper switch removed or loose in the dash do you?
See if this thread helps at all:
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
LockDoc
LockDoc
Leon
Old 04-25-2019, 10:42 PM   #11
HIGHWAY BY THE SEA
LockDoc
LockDoc
Here are pictures that I took tonight.
Old 04-25-2019, 11:31 PM   #12
LockDoc
LockDoc's Avatar
I'm not seeing the Black wire on the third terminal on the motor. It must be hanging under there somewhere..... Check this picture out.
LockDoc
Leon
Old 04-25-2019, 11:45 PM   #13
HIGHWAY BY THE SEA
Just went outside and checked, and you were right there was no black wire attached. I found the detached black wire and attached it but the wiper still does not work.
Old 04-25-2019, 11:55 PM   #14
LockDoc
LockDoc's Avatar
Did you have the ignition switch on when you tried it?
LockDoc
Leon
Old 04-26-2019, 12:06 AM   #15
HIGHWAY BY THE SEA
LockDoc
Yes. I am leaving town tomorrow, and will not be able to work on the truck until next week.
Old 04-26-2019, 12:54 AM   #16
LockDoc
LockDoc's Avatar
I will do some thinking while you are gone.
LockDoc
Leon
Old 04-26-2019, 01:20 AM   #17
Fbks_Cruiser
Fbks_Cruiser's Avatar
As LockDoc mentioned in post #10 check that the switch is tight in the dash. It has to be tight as it completes the ground side of the circuit from that black wire. I went through this a while ago. Wiper motor didn’t run properly turned out to be ground issue.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 05-01-2019, 07:44 PM   #18
HIGHWAY BY THE SEA
Wiper motor "crank" nut size?
Anyone know off of the top of their head what size nut attaches the wiper crank to the motor? I had mine in a box on the truck's flatbed with other parts, and when I left to get a drink then returned minutes later the box was on the ground with parts scattered everywhere (I suspect the cat). I found all the parts EXCEPT the wiper crank retention nut. Once I know the size I will get another from the hardware store.
Old 05-01-2019, 09:15 PM   #19
elf w/capital T
I just removed mine, your missing the pump and the gear from the motor, under the three terminals...
elf w/capital T is offline   Reply With Quote
Old 05-03-2019, 06:18 PM   #20
HIGHWAY BY THE SEA
Wiper motor lacks power
I tested the wires that attach to the wiper motor today, and they do not have power. I also checked the power at the fuse box, and there is none there either.
And I still need to know the retention-nut size for the "crank".
Old 05-27-2019, 03:51 PM   #21
HIGHWAY BY THE SEA
The wiper switch seems to test as "bad" so I am buying another one. This one sometimes did not want to turn off.
I also made a lucky guess and got the correct size retention nut for the wiper crank to replace the one that got lost.
Old 04-22-2020, 11:48 PM   #22
HIGHWAY BY THE SEA
***update***
After a year of not working on the GMC much I have recently been tackling all the things that overwhelmed me last year. I intend to attack the wiper motor again tomorrow if the (CENSORED) rain will stay the Hell away. If it bench tests good I will then attack the grounding issues.
Old 04-23-2020, 10:38 AM   #23
LockDoc
LockDoc's Avatar
Re: ***update***
Look at the Brown wiring connector on the picture I posted in post #12 it looks to me like yours is plugged in with the Yellow wires on the wrong side of the connector. Try flipping that connector over so the Yellow wires are on the other side like my picture shows.
LockDoc
Leon
Old 04-23-2020, 08:05 PM   #24
HIGHWAY BY THE SEA
Re: ***update***
LockDoc
I tried that and it still did not work. And of course the RAIN showed up AGAIN!!
So I was not able to start checking electrical connections and grounds again. I did Dremel the fuse connector for the wipers, but that did nothing also. As soon as the rain goes the Hell away I will try again.
Old 04-23-2020, 08:36 PM   #25
RustyPile
RustyPile's Avatar
This has been going on for a year, it's time we get those wipers working..
The yellow wire comes from the "Ignition on" terminals in the fuse box and carries voltage to the wiper motor.. The switch provides the ground path through the 2 blue wires for each speed.. The switch HAS TO BE GROUNDED TO THE DASH.. The yellow wire is hot with the ignition switch in the ON position.. If there is no voltage present on the yellow wire, there is an open (as opposed to a short) or bad connection somewhere.. Find the open, (don't forget the fuse and it's connections) repair it, and the wiper motor should work..
RustyPile is online now   Reply With Quote
